I’m trying to add the holidays library to one of my Python rules and have been unsuccessful so far. I’m running a standard openhabian installation on a RPi3 with openhab 2.5.8.
When I run
pip install holidays
at the command line it says it installs correctly but adding the line
import holidays
at the start of my rule doesn’t succeed and I see the following in my logs;
2020-11-13 09:48:16.785 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab2/automation/jsr223/python/personal/time_of_day.py': ImportError: No module named holidays in <script> at line number 4
A bit of hunting through the forums here revealed that there are some user and directory issues that need to be incorporated into the pip installation process, so I tried the following;
sudo -u openhab pip install --ignore-installed --install-option="--prefix=$OPENHAB_CONF/automation/lib/python/personal" holidays
but this failed. The output from this is as follows;
/usr/lib/python2.7/dist-packages/pip/_internal/commands/install.py:222: UserWarning: Disabling all use of wheels due to the use of --build-options / --global-options / --install-options.
cmdoptions.check_install_build_global(options)
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting holidays
Using cached https://files.pythonhosted.org/packages/d9/c7/1d0cb8f69bb4caa252a0c95de66a34e0548cbf9d3f4a2353cba5ee5f566c/holidays-0.10.3.tar.gz
Collecting convertdate (from holidays)
Using cached https://files.pythonhosted.org/packages/da/57/2d01124f7122665d864ce510315fb1e458635bb65dfb4741fff3227fd7c5/convertdate-2.2.2.tar.gz
Collecting korean_lunar_calendar (from holidays)
Using cached https://files.pythonhosted.org/packages/fa/c4/2f0f2329098ee24f629c3ad4dcb210fbedb52e51fa6348ebdcbd7af2151b/korean_lunar_calendar-0.2.1.tar.gz
Collecting python-dateutil (from holidays)
Using cached https://files.pythonhosted.org/packages/be/ed/5bbc91f03fa4c839c4c7360375da77f9659af5f7086b7a7bdda65771c8e0/python-dateutil-2.8.1.tar.gz
Installing build dependencies ... error
Complete output from command /usr/bin/python -m pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-yBGSFg --no-warn-script-location --no-binary :all: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- "setuptools; python_version != '3.3'" "setuptools<40.0; python_version == '3.3'" wheel setuptools_scm:
Ignoring setuptools: markers 'python_version == "3.3"' don't match your environment
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple, https://www.piwheels.org/simple
Collecting setuptools
Using cached https://files.pythonhosted.org/packages/b2/40/4e00501c204b457f10fe410da0c97537214b2265247bc9a5bc6edd55b9e4/setuptools-44.1.1.zip
Collecting wheel
Using cached https://files.pythonhosted.org/packages/83/72/611c121b6bd15479cb62f1a425b2e3372e121b324228df28e64cc28b01c2/wheel-0.35.1.tar.gz
Complete output from command python setup.py egg_info:
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/pip-install-iXHpqb/wheel/setup.py", line 4, in <module>
setup(maintainer=u'Alex Grönholm')
File "/usr/lib/python2.7/dist-packages/setuptools/__init__.py", line 144, in setup
_install_setup_requires(attrs)
File "/usr/lib/python2.7/dist-packages/setuptools/__init__.py", line 139, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 724, in fetch_build_eggs
replace_conflicting=True,
File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 782, in resolve
replace_conflicting=replace_conflicting
File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 1065, in best_match
return self.obtain(req, installer)
File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 1077, in obtain
return installer(requirement)
File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 791, in fetch_build_egg
return cmd.easy_install(req)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 704, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 730, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 915, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1183, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1169, in run_setup
run_setup(setup_script, args)
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 233, in run_setup
with setup_context(setup_dir):
File "/usr/lib/python2.7/contextlib.py", line 17, in __enter__
return self.gen.next()
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 195, in setup_context
yield
File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
self.gen.throw(type, value, traceback)
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 166, in save_modules
saved_exc.resume()
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 141, in resume
six.reraise(type, exc, self._tb)
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 154, in save_modules
yield saved
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 194, in setup_context
__import__('setuptools')
File "setuptools/__init__.py", line 16, in <module>
File "setuptools/version.py", line 1, in <module>
File "pkg_resources/__init__.py", line 1365
raise SyntaxError(e) from e
SyntaxError: invalid syntax
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-iXHpqb/wheel/
Command "/usr/bin/python -m pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-yBGSFg --no-warn-script-location --no-binary :all: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- "setuptools; python_version != '3.3'" "setuptools<40.0; python_version == '3.3'" wheel setuptools_scm" failed with error code 1 in None
I’m still pretty new to Python, but is this telling me that this library is written for Python 3 and therefore I won’t be able to install it? Is there any sort of workaround here? Why did it not fail when I ran the initial simple ‘pip’ command?
