evets.log > 2015-11-23 23:46:05 - Flic01click received command ON
Unfortunatelly the rule does not get executed when I set “autoupdate=false”.
I think it’s too late for me to think straight.
What am I missing?
Is there a better way to integrate the devices?
btw: There might be a linux library in the works. +1:
Can’t wait for the full API from shortcut labs or someone to reverse engineer a binding, mine are in the post and would be good if they worked without a phone
I’ve been lucky enough to be testing a linux/raspberry pi integration (finally!) for the flic buttons. Seems to work well, and means I don’t need to rely on a mobile device. Not open source yet but they’re releasing it together with java/python bindings hopefully in the next day or so. Then we can do a proper openHAB integration
For those of us with an iPhone, this wasn’t an option as there’s no Tasker. A really easy, reliable, and fast way to integrate the Flic buttons was through the Flic app on the phone and creating an “HTTP request” and then using the following:
I started today on working on a OpenHab 2 binding for this library, but I’m very new to the OpenHab development, so it could take some time. But I’ll publish a first draft on GitHub soon. Unfortunately, I doubt that this one could be integrated to the openhab2-addons repository at the moment, because there is a license conflict. The java clientlib by Shortcut Labs is not open source as it must be used only with Shortcut Labs products (see here: https://github.com/50ButtonsEach/fliclib-linux-hci/issues/35). Therefore, it’s not compatible with the required sign-off: https://github.com/openhab/openhab2-addons/blob/master/CONTRIBUTING.md#sign-your-work
Hopefully, they’ll publish the clientlib to a maven repo soon. This would erase the need of including the sources into the addon.
reviews, hints and any other help are welcomed. (Please consider that this is a very early state of development - of course there is much that’s not perfect right now)
Anyone have flic button directly working with OpenHab?
I want to build a Raspberry3 implementation so I can connect my flics to the Raspberry instead of my phone and get home automation. I plan to integrate with my current HA setup which is built on SmartThings but I plan to migrate away from the ST hub to a full OpenHab implementation. Flic will be my first OpenHab implementation if I can get it working.
I will also start to play with my flic so I’m very interested in your work.
Did the 0.5 alpha always need the java clientlib to be installed separately ? so we need to install the Flic SDK for Linux before ?
