Hi everyone,
Just a quick note to try and help anyone that is planning to use some XBee3 on a Zigbee network that is handled by a Nortek HUSBZB-1 usb stick.
Here is how I’m configured.
Docker image openhab/openhab:snapshot (2.5.0-snapshot at this time)
Nortek usb dongle HUSBZB-1 on /dev/ttyUSB1 configured with the Zigbee binding
The XBee3 chip model I got: XB3-24Z8PT-J
I’ts using firmware: Digi XBee3 Zigbee 3.0 TH version 1005
From what I found the most important parameter to setup right away is the Zigbee stack ZS. It has to be 2. 2 is identified in XCTU as Zigbee Pro.
ATZS2 is the command to use.
The other parameters that you’ll need to change are:
CE: 0
EE: 1
EO: 2 (I’m really not sure this is needed)
Then to get a succesful join I went to the OpenHab mail box and started a Zigbee discovery and gave the XBee3 the ATCB2 command in the Serial terminal of XCTU and voilà. OpenHab detected the device.
