Hi i am new to openhab 3 so im still trying but i am making some progress and now stuck to this question:
How can I label channels within a thing using files and not the UI?
Below I add lable=“Fenster” to the first channel but it still shows me On/Off Switch in the UI.
My goal is to use different lables for the channels to be able to identify the things in Visual Studio code with the openhab addon.
Otherwise all switch channels will have the same name ;(
Please, if using text file configuration, keep in mind that only newly created channels are configured correctly without restart. This is due to the fact, that openHAB1 did not have a things folder nor things at all.
So there was some copied code to build the same functionality as with items, but there are some differences between items and things, so the code does not work 100% same way.
