- Platform information:
- Hardware: RPi 3B+
- OS: Raspbian
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 2.5.M5
- Issue of the topic:
What is the password to login as user openhab??
I tried habopen and found it says Authentication failure
I want to ssh into the Pi with user openhab.
I think you are looking for that?
Sorry, but I couldn’t find how to login.
I am using raspbian lite and installed openhab as a packaged repo.
Now I wanted to install helper libraries and in the steps written on this Page Installation — openHAB Helper Libraries documentation, in step 7 it says to copy the contents as openhab user.
How to accomplish that?
You need to set-up this first:
The openhab user cannot be logged into. That is by design. You want to limit what a service can do.
To perform actions as the openhab user, use sudo -u openhab.
Thanks a lot @rlkoshak.
You are a life saver. ![]()
