Hey Forum,
I’m using openHAB version 4.3.0 on KVM running Ubuntu 22.04 LTS and using Java 17.
I have a room (location) in the semantic model having three equipments with all having a temperature sensor. They differ much, due to the room layout. One of them is located under a roof top window with a windows shaft and usually shows a five degree lower temperature than the one at the rooms entry.
One of them is regarded the main temperature sensor and so I want to show this value as the badge temperature on the location card.
Currently the badge uses one of the three temperature sensors but it is not the one I want to use as the main temperature sensor.
Is it possible to tag one of the three temperature sensors as the one picked up by the badge of the location card?
If not how would you achieve this with other measures?
Kind regards,
Frank
