How to migrate from manually downloaded binding.jar
Hey everyone,
I am currently beta testing a binding that will be released in one of the next releases of openhab.
Now I am curious how the migration would be done for that case.
Would I just install the binding and remove the jar of the manual installation?
Opposite way round..
Remove the jar and then install from the ui :slight_smile:
Will the things be kept by openhab? :smiling_face:
Yes, unless you delete them. The only time I believe they’ll be an exception to this is if something like the following happens:
Openhab2 had a binding intesisbox (custom jar)
Things were created for this binding.
IntesisHome was then added to the binding
Binding was renamed to intesis for OH3
Thank you so much :slight_smile:
