How to mount external HDD and share with samba?
  • Platform information:
    • Hardware: RPI4 4GB
    • OS: openhabian 3.0.2
    • Java Runtime Environment: which java platform is used and what version
    • openHAB version:
  • Issue of the topic: mount external storage and share with samba
What I would do is,
Give your USB device a static name and share it as a normal HDD/folder
There are many examples on the internet
There will also be other solutions. but I use these for my z-wave and zigbee stick.
I don’t want to recommend something I’ve never used myself.
But I am not an expert on Linux
To give you a starting point:
Samba info pi os
sudo nano /etc/samba/smb.conf
add the line below to your conf file and fill in your own values
[sharename]
path = path to mount
available = yes
valid users = usename
read only = no
browseable = yes
public = yes
writable = yes
sudo systemctl restart smbd
Samba Add a User
useradd joe
passwd joe
smbpasswd -a joe
Did you search, since there are literally tons of articles on how to do that:
https://www.raspberrypi.org/documentation/configuration/external-storage.md
or step by step guide:
