When dividing the .items file into several .items files, the order in which the items appear in Basic UI and Clasic UI varies from the order that is set.
I have noticed that the last .items file that you modify, places it in last place in both Basic and Clasic UI.
Is there any way to set the order in which items are displayed ??
How is your sitemap defined?
Do you display Groups in the sitemap or individual items?
A single .sitemap showing the main frames
Multiple .items files
Sorry for my english the google translator
Well, the order in which items are displayed in the UIs (Basic and/or Classic) is managed mainly in the sitemap file.
Within the sitemap file, you can list your stuff. I usually use a mix of Groups and individual items.
The sorting of the Group members is coming from the items file.
So: If you want to have full control on how stuff are sorted in your sitemap, use individual item entries and sort them manually.
I hope that I explained it correctly
The entries in .sitemap, are correct and ordered by frames, there is no problem in the orderly visualization.
When it shows in subscreen the items belonging to it, it is when they are disordered, they maintain an order and it is the last modified .items, it is placed at the end of the sub-screen.
Main screen calls room child
Child room has several .items
temperature
light
humidity
etc
Each parameter is in a file.items that contains all the rooms
When modifying any of the .items files is placed at the end of the screen.
example
If I modify the file temperatura.items
The order of appearance in the child’s room would be:
light
humidity
etc
temperature
I would be best if you can post your sitemap config.
From what I understand, you are using Groups in your sitemap and your various items (distributed across many items files) are members of those Groups.
To control the sorting in this case (and avoid the placement at the end of the most updated group members), you would have to define manually the sitemap config… or place your items in less files.
Another way would be to use subgroups in the Groups.items file and sort them there
Example (Groups.items):
Group gAll
Group gGF (gAll)
Group gGF_Child_Room (gGF)
Group gTemp (gAll)
Group gLights (gAll)
Group gHumid (gAll)
In theory, when you use gGF_Child_Room (or gGF or gAll) in your sitemap, it should show Temp, then Lights and then Humidity items as sorted above.
My intention was to have the maximum structured, with the minimum code.
For what I understand, the simplest thing is when I finish creating all the .items files, is to leave them sorted. That is, open, edit and save, in the order I want them to appear.
I think it will generate a .bat file that does it automatically, perhaps it is the simplest.
Thanks for your time and help
Sorry it does not translate correctly, this is my sitemap
When I have the items running, I create a .tems file and I move it there
indent preformatted text by 4 spaces
sitemap demo label=" TDR i d'Investigació -- Casa intel·ligent amb un sistema domòtic"
Frame {
Group item=gFF label="Zona Silenci" icon="silenci"
Group item=gGF label="Zona Habitatge" icon="vida"
Group item=gC label="Zona Magatzem" icon="magatzem"
Group item=Garden label="JardĂ" icon="garden"
Frame label="El Temps" {
Text item=Weather_Temperature {//valuecolor=[Weather_LastUpdate=="NULL"="lightgray",Weather_LastUpdate>90="lightgray",>25="orange",>15="green",>5="orange",<=5="blue"]
Frame {
Text item=Weather_Temperature valuecolor=[>25="orange",>15="green",>5="orange",<=5="blue"]
Text item=Weather_Temp_Max valuecolor=[>25="orange",>15="green",>5="orange",<=5="blue"]
Text item=Weather_Temp_Min valuecolor=[>25="orange",>15="green",>5="orange",<=5="blue"]
Text item=Humidity
Text item=Weather_Pressure
Text item=Weather_LastUpdate //visibility=[Weather_LastUpdate>10] valuecolor=[Weather_LastUpdate>120="orange", Weather_LastUpdate>300="red"]
Frame {
Switch item=Weather_Chart_Period label="GRĂ€FIC" mappings=[0="Hores", 1="Dia", 2="Setmana"]
Chart item=Weather_Chart period=h refresh=600 visibility=[Weather_Chart_Period==0, Weather_Chart_Period=="NULL"]
Chart item=Weather_Chart period=D refresh=3600 visibility=[Weather_Chart_Period==1]
Chart item=Weather_Chart period=W refresh=3600 visibility=[Weather_Chart_Period==2]
Text label="DADES ASTRONĂ’MIQUES" icon="sun" {
Text item=Sun_Elevation
Text item=Sun_Azimuth
Text item=Sunrise_Time
Text item=Sunset_Time
Text item=Moon_Elevation
Text item=Moon_Azimuth
Frame label="General" {
Text item=CurrentDate
Text label="Estat General" icon="status" {
Switch item=Lights mappings=[OFF="Tancar"] icon="light"
Group item=Heating
Group item=Windows
Switch item=Persiana mappings=[DOWN="Baixar"] icon="Rollershutter"
Text item=Temperature
Text label="Estat de les bateries" icon="bateria" {
Text label="_______________HabitaciĂł de la Teresa " icon="girl_2"
Text item=bateria_FF_Bed_TH label="Temperatura"
Text item=bateria_FF_Bed_Finestra label="Finestra"
Text item=bateria_FF_Bed_pir label="Presencia"
Text label="_______________HabitaciĂł de David " icon="boy_3"
Text item=bateria_FF_Bed2_TH label="Temperatura"
Text item=bateria_FF_Bed2_Finestra label="Finestra"
Text item=bateria_FF_Bed2_pir label="Presencia"
Text label="_______________HabitaciĂł dels pares " icon="parents_1_3"
Text item=bateria_FF_Bed3_TH label="Temperatura "
Text item=bateria_FF_Bed3_Finestra label="Finestra"
Text item=bateria_FF_Bed3_pir label="Presencia"
Text label="_______________Oficina " icon="office"
Text item=bateria_FF_Office_TH label="Temperatura "
Text item=bateria_FF_Office_Finestra label="Finestra"
Text item=bateria_FF_Office_pir label="Presencia"
Text label="Temperaturas de Consigna" icon="temperature" {
Frame label="Histèresis" {
Setpoint item=set_Histeresis label="Histèresis" icon="temperature" step=0.5 minValue=0 maxValue=10
Setpoint item=set_Diposit_inercia label="Diposit d'inèrcia" icon="temperature" step=0.5 minValue=0 maxValue=70
Frame label="Consigna Temperaturas" {
Setpoint item=set_Bany label="Bany" icon="temperature" step=0.5 minValue=10 maxValue=25
Setpoint item=set_Oficina label="Oficina" icon="temperature" step=0.5 minValue=10 maxValue=35
Setpoint item=set_Dormitori_Teresa label="Dormitori Teresa" icon="temperature" step=0.5 minValue=10 maxValue=35
Setpoint item=set_Dormitori_David label="Dormitori David" icon="temperature" step=0.5 minValue=10 maxValue=35
Setpoint item=set_Dormitori_Pares label="Dormitori Pares" icon="temperature" step=0.5 minValue=10 maxValue=35
Setpoint item=set_Passadis label="Passadis" icon="temperature" step=0.5 minValue=10 maxValue=25
Setpoint item=set_Sala_Estar label="Sala d'Estar" icon="temperature" step=0.5 minValue=10 maxValue=25
Setpoint item=set_Cuina label="Cuina" icon="temperature" step=0.5 minValue=10 maxValue=25
Setpoint item=set_Lavabo label="Lavabo" icon="temperature" step=0.5 minValue=10 maxValue=25
Setpoint item=set_Rebedor label="Rebedor" icon="temperature" step=0.5 minValue=10 maxValue=25
Text label="Preus energia " icon="temperature" {
Frame label="Preus en c€/kWh " {
Setpoint item=set_gasoil label="Gasoil" icon="temperature" step=0.01 minValue=0 maxValue=15
Setpoint item=set_electricitat label="Electricitat" icon="temperature" step=0.01 minValue=0 maxValue=15
Setpoint item=set_gas label="Gas Natural" icon="temperature" step=0.01 minValue=0 maxValue=15
Setpoint item=set_pellet label="Pellet" icon="temperature" step=0.01 minValue=0 maxValue=15
Text label="CĂ meres de seguretat" icon="camera" {
Frame label="CĂ meres de seguretat" icon="camera"{
Text item=camera1 label="CĂ mera exterior" icon="camera_ext" {
Webview url="http://***.***.org:81/image/Cam1?q=50&s=50" height=16
muestra foto
time=20817" height=14 //encoding="mjpeg" ///bcs/channel0_main.bcs?channel=0&stream=0&user={id}&password={pw}
Text item=camera2 label="CĂ mera magatzem" icon="camera" {
Webview url="http://**********:81/login.htm?page=%2Fimage%2FCam1"
Text item=camera3 label="CĂ mera jardĂ" icon="camera_ext" {
Webview url="http://*******:81/login.htm?page=%2Fimage%2FCam1"
Text item=camera4 label="CĂ mera passadĂs" icon="camera"{
Webview url="http://********:81/login.htm?page=%2Fimage%2FCam1"
Text item=camera5 label="CĂ mera menjador" icon="camera"{
Webview url="http://******.org:81/login.htm?page=%2Fimage%2FCam1"
Text item=camera6 label="CĂ mera entrada" icon="camera"{
Webview url="http:/*******.org:81/login.htm?page=%2Fimage%2FCam1"
Frame label="Map/Location" {
// Mapview item=DemoLocation height=10
Text label="Preséncia de mòbils a casa" icon="icomovil" {
Frame label="Mòbils detectats dins de casa" icon="icomovil"{
//Switch Phone_Mobile "My Mobile Phone" { channel="mxavier:online" }
//Text item=192_168_1_52 label="Device [%s]"
Switch item=mteresa label="Mòbil Teresa" icon="icomovil" mappings=[ON="SI",OFF="NO"]
Switch item=mdavid label="Mòbil David" icon="icomovil" mappings=[ON="SI",OFF="NO"]
Switch item=txavier label="Tablet Xavier" icon="icomovil" mappings=[ON="SI",OFF="NO"]
Switch item=mxavier label="Mòbil Xavier" icon="icomovil" mappings=[ON="SI",OFF="NO"] // { network:device:192_168_1_52:online }
Switch item=mmontse label="Mòbil Montse" icon="icomovil" mappings=[ON="SI",OFF="NO"]
Switch item=mlladre label="Presència ALIENA" icon="ladron" mappings=[ON="SI",OFF="NO"]
Text label= "IP" icon=""
Frame {
Text item=Network_WAN_IP
// Text label= "CALENDARI"
// Frame label="CALENDARI" {
// Webview url="/static/GoogleCalendar.html" height=11
// Webview url="https://calendar.google.com/calendar/render#main_7" height=11
// Webview url="https://www.google.com/calendar?tab=cc&authuser=0" height=11
You have no control over the order of items when you use Group on your sitemap.
If you care about ordering of your items, or if you want to customize how an item appears (e.g. Show a Switch without the toggle control icon, change the color of a label based on its state, etc) you must put each item on your sitemap individually.
No other approach will guarantee the order of how the others appear.
