It was really easy to pair my two hue bridges with openHAB but wich is the right identifier for the hue bridges?
“Color Wohnzimmer1 “Deckenlampe-1” (WoziDecke, Lampen) {hue=“15”}”
does not work. How do Iselect one of the two bridges?
I would appreciate a short example as well!
Maybe there is any known tutorial around, that explains how to bind multiple bridges (including some item configurations)?
The example can be found here: https://github.com/eclipse/smarthome/blob/master/extensions/binding/org.eclipse.smarthome.binding.hue/README.md#full-example
See the demo.items:
Color Light { channel="hue:LCT001:1:bulb1:color" }
Dimmer Light_ColorTemp { channel="hue:LCT001:1:bulb1:color_temperature" }
So if you want to add a Light2 from a second bridge (to be defined in the things-file as well), you would simply have
Color Light { channel="hue:LCT001:2:bulb1:color" }
