Actually it can if you install the Block library: Mail Actions
You can install that from Add-on Store → Automation → Block Libraries.
In Rules DSL you don’t. Rules DSL doesn’t support receiving values passed into the script like that.
Your options are (in order of preference):
- install and use the Block library and do away with the whole rule calling in the first place
- implement the called rule using JS Scripting instead of Rules DSL
- use the
sharedCacheto store the value in the calling rule and retrieve the value in the called rule
