How to read power consumption with Fibaro FGWP102 Wall plug?
Hardware: raspberryPI 3 + Aeon Labs Z-stick gen 2
OS: Linux openHABianPi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l
openHAB version: 2
Issue of the topic: Can’t read meter_watts
I have a Fibaro Wall plug (FGWP102) and I set this up:
default.items
Switch m06_switch “m06 switch” { channel=“zwave:device:f511b9a2:node2:switch_binary” }
Number m06_power “power [%.1f] W” { channel=“zwave:device:f511b9a2:node2:meter_watts” }
default.sitemap
sitemap default label=“Control”
Switch item=m06_switch label=“M06 Switch”
Text item=m06_power label=“M06 Power [%.1f]”
My sitemap in basic UI shows a switch, that works to turn it on and off, but the power meter always shows zero. I have some questions:
  1. What does the label in items do, since I need to write a new one in the sitemap?
  2. How do I get the actual power usage to show up? I tried with and without [%.1f] in the sitemap. I also didn’t get it working with Number in sitemap, so I used Text. I also tried “m06 power [%.1f]” in the items file, but to no avail.
I fiddled with the REST API to see something, but this is all I see:
“link”: “http://192.168.1.188:8080/rest/items/m06_switch”,
“state”: “ON”,
“type”: “Switch”,
“name”: “m06_switch”,
“label”: “m06 switch”,
“category”: “switch”,
“tags”: ,
“groupNames”:
“link”: “http://192.168.1.188:8080/rest/items/m06_power”,
“state”: “NULL”,
“stateDescription”: {
“pattern”: “%.1f”,
“readOnly”: false,
“options”:
“type”: “Number”,
“name”: “m06_power”,
“label”: “power”,
“category”: “poweroutlet”,
“tags”: ,
“groupNames”:
Perhaps I’m doing something wrong with the plug so it doesn’t send out the wattage, but I think it should by default.
Thank you in advance!
Wait a minute, now it suddenly shows 3.0. Perhaps there is some delay in the readings, was I to impatient? :slight_smile: However when I shut it off, i expected it to go to 0.. still 3.0. weird :slight_smile:
I found the settings to change when it shall update, and default is 80% change in value, which I thing is pretty much. However, when I try to change this in PaperUI, I get 500 Internal server error, and in the logs, it looks like this. Why is this happening?
2018-02-24 01:42:04.643 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zwave:device:f511b9a2:node2/config’
java.lang.ClassCastException: java.math.BigDecimal cannot be cast to java.lang.Integer
at org.openhab.binding.zwave.handler.ZWaveThingHandler.handleConfigurationUpdate(ZWaveThingHandler.java:749) [231:org.openhab.binding.zwave:2.2.0]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:94) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:413) [126:org.eclipse.smarthome.io.rest.core:0.10.0.b1]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
It seems to work when I changed it in Habmin instead…
