How to read values from Esera 1-Wire Controller
1wire
Tags: #<Tag:0x00007f1e6bcb05d0>
(Digitalvitamin) #1
Hi all,
I’m happily running openHAB for a while and now planning to buy the 1-Wire controller 1 from esera.
Has anyone managed to read values from such a device? If yes, how? It has a TCP/UDP interface. So I should be able to use the HTTP-binding?
They provide a “software module” for FHEM.
As an alternative: Are there other “modern” 1-wire controllers that are easy to integrate into openHAB? My requirements:
  • Support at least 30 1-wire devices
  • Support DS2450 & DS2438
  • Support “long” bus (2 loops at ~25 meters each)
    I know for example HA7Net. But it’s quite old and does not support DS2450. Also I would need OWFS which I’m trying to avoid.
Thanks!
(Digitalvitamin) #2
Update: There seems to be some activity in the German knx-user-forum.
Someone seems to be using NodeRed to read values from the controller (which could be connected to the MQTT binding).
Someone else recommends the TCP/UDP binding.
I would like to avoid another service in the middle (MQTT) but judging from the documentation the TCP binding seems to have a major bug :face_with_raised_eyebrow:.
(Digitalvitamin) #3
I managed to read values using the TCP binding just like this:
String OWinput { tcp=">[192.168.0.120:5000:default]"}
However: sometimes the input is cut in the middle. See here.
