Hi experts,
as a newbe in the openhab community, I am struggeling with some maybe simple and stupid questions.
I am trying to connect to my raspi via putty or windows ssh.
With my “old and wellknown” commands ssh pi@my-raspi-at-home and the password raspberry, I have no success. Also all other combinations, that I found like openhabian:openhabian, openhabian:habianopen … does not work an I receive a simple “access denied”
the only thing, that i want to do is → sudo reboot
So my question: what is the right username:password to access the raspi shell.
Hi Jonathan,
My enviroment:
HW: Raspi 3B
SW: I used the openhabian image, where everything should be fine and prepared for beginners
To your question about “is ssh enabled?” – > I simply do not know.
With my normal raspi experiences, I use an image and install everything by hand. Here I know, that I have to use the raspi configuration to enable ssh, but with using the image, I have never seen this option.
Perhaps you can give me a hint, where I can properly enable ssh
All information for installing openhabian correctly shall be found at openHABian | openHAB
IMHO, ssh should be enabled by default as openhabian is dedicated for headless use.
If ssh is not enabled, try to add a file named “ssh” (without extension) to the boot partition of the as card. See here e.g. for detailed information: How to Enable SSH on Raspberry Pi (see section about headless mode).
For me the OH docu regarding openhabian is correct. User and password in ssh is openhabian:openhabian by default. I just setup a new openhabian SD card two days ago…
Are you sure, you are referencing the normal raspi shell and not the openhab console - where indeed the password is habopen by default - but belongs to the user openhab…
One comment to this one: If the file exists on the partition, ssh gets enabled and afterwards the file will be deleted. ssh stays active until you would disable it.
