How to remove or edit widget without UI?
Welcome to the forums Andrew.
Yes, it is possible. Json formatted files for most OH info are found the the ./userdata/jsondb folder. In this case the file you are looking for is the uicomponents_ui_widget.json. BEFORE you try this, check out the Editing the JSONDB, a last resort section of the Rich’s post here for some safety tips:
