I would like to try a snapshot version of the org.eclipse.smarthome.core.jar file, but I don’t know what’s the right way to replace this jar. I tried to just replace the jar file in the folder /usr/share/openhab2/runtime/system/org/eclipse/smarthome/core/org.eclipse.smarthome.core/0.9.0.b5 but that didn’t change anything.
After that I tried to uninstall the 0.9.0.b5 core bundle in the karaf console and added the snapshot jar file to the addons folder and started it using karaf. Now I get some strange errors in the log and PaperUI isn’t working anymore:
2017-07-11 12:12:50.896 [INFO ] [org.eclipse.smarthome.ui.paper ] - FrameworkEvent INFO - org.eclipse.smarthome.ui.paper
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; osgi.identity="org.eclipse.smarthome.ui.paper"; type="osgi.bundle"; version:Version="0.9.0.b5"; singleton:="true""
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassPathEntry(ClasspathManager.java:176)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.buildClasspath(ClasspathManager.java:154)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.<init>(ClasspathManager.java:83)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.loader.EquinoxClassLoader.<init>(EquinoxClassLoader.java:57)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoaderPrivledged(BundleLoader.java:277)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:224)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.loader.BundleLoader.findEntries(BundleLoader.java:777)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleWiring.findEntries(ModuleWiring.java:289)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.storage.ManifestLocalization.findResource(ManifestLocalization.java:200)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.storage.ManifestLocalization.lookupResourceBundle(ManifestLocalization.java:131)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.storage.ManifestLocalization.getResourceBundle(ManifestLocalization.java:102)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.storage.ManifestLocalization.getHeaders(ManifestLocalization.java:63)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.storage.BundleInfo$Generation.getHeaders(BundleInfo.java:124)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.privGetHeaders(EquinoxBundle.java:471)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:466)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:460)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.apache.aries.spifly.BaseActivator.addConsumerWeavingData(BaseActivator.java:96)
at org.apache.aries.spifly.ConsumerBundleTrackerCustomizer.addingBundle(ConsumerBundleTrackerCustomizer.java:37)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker.open(BundleTracker.java:156)[org.osgi.core-6.0.0.jar:]
at org.apache.aries.spifly.BaseActivator.start(BaseActivator.java:81)
at org.apache.aries.spifly.dynamic.DynamicWeavingActivator.start(DynamicWeavingActivator.java:37)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_131]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.doStart(Module.java:571)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:439)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
What is the correct way to install a snapshot of core jar files and how do I revert back to the release versions?
