- Platform information:
- Hardware: CPUArchitecture/RAM/storage --> works on an Synology
- OS: what OS is used and which version --> Synology OS
My issue is that i skip the first time setup Menu to choose a installation . How can i start this menu again?
At the moment on the installationpage every time the same text:"Please stand by while UIs are being installed. This can take several minutes." and nothing happens.
Could you help me?
Excuse my English.
Thx
Speedyggg
There should be a services folder with a addons.cfg file that you can specify expert and then define what you want installed in the rest of the file.
# The installation package of this openHAB instance
# Note: This is only regarded at the VERY FIRST START of openHAB Note: If you want to specify your add-ons yourself through entries below, set the package to "minimal" as otherwise your definition might be in conflict with what the installation package defines.
# Optional. If not set, the dashboard (https://<yourserver>:8080/) will ask you to choose a package.
# Valid options:
# - minimal : Installation only with dashboard, but no UIs or other add-ons. Use this for custom setups.
# - simple : Setup for using openHAB purely through UIs - you need to expect MANY constraints in functionality!
# - standard : Default setup for normal users, best for textual setup
# - expert : Setup for expert users, especially for people migrating from openHAB 1.x
# See http://docs.openhab.org/configuration/packages.html for a detailed explanation of these packages.
package = expert
Yeah, great . That’s it. It works.
Thanks a lot!
