How to set timer value with a variable?
Hi All,
I have a few rules with timers similar to the line below:
FamilyRoomLightTimer = createTimer(now.plusMinutes(5)) [|
Do Something Cool.....]
In the example above I’d like to use a variable or better yet a number item to replace the “5”.
I would like the timers to be more dynamic based on time of day, occupancy, weather, etc and it would be far less lines of code to use a variable VS rewriting the entire rule block with separate conditions. If I substitute the “5” with anything that’s not a number I get errors in designer.
Is there a way to pull this off?
If you have a Number variable you would use the intValue method to get a primitive int which now.plusMinutes requires.
var Number myNum
// code that populates mynum
FamilyRoomLightTimer = create(now.plusMinutes(myNum.intValue)) [|
    // do stuff
Brilliant!! Thanks Rich!
Just so all my bases are covered, how would I use the value of a number item to accomplish the same thing?
now.plusMinutes((MyItem.state as DecimalType).intValue)
Thank you Rich! That works awesomely!! Thank you, Thank you.
