How to set up a controlled garage door?
Just to show a way of doing this
My items
Switch GarageDoorSwitch		 [ "Switchable" ] 									{ mqtt=">[broker:cmnd/GarageDoorSonoff/POWER:command:*:default]" }
Rollershutter GarageDoor
String GarageDoorState
Switch GarageDoorClosed															{ mqtt="<[broker:cmnd/GarageDoorSensors/POWER1:state:default]" }
Switch GarageDoorOpened															{ mqtt="<[broker:cmnd/GarageDoorSensors/POWER2:state:default]" }
Number Garage_RSSI 	"Garage: RSSI [%d %%]"  									{ mqtt="<[broker:tele/GarageDoorSonoff/STATE:state:JSONPATH($.Wifi.RSSI)]" }
String Garage_IP 	"Get Info"  												{ mqtt=">[broker:cmnd/GarageDoorSonoff/IPAddress1:command:*:*]" }
String Garage_IP_String "Info [%s]"	 											{ mqtt="<[broker:stat/GarageDoorSonoff/RESULT:state:default]" }
Switch GarageDoorAuto "Garage Door auto close 9PM-5AM"
Switch GarageDoorStateUpdate 													{ mqtt=">[broker:cmnd/GarageDoorSonoff/STATUS:command:*:10]" } //hidden button to get update of garage door status. Runs every minute
String GarageDoorStateString													{ mqtt="<[broker:tele/GarageDoorSonoff/SENSOR:state:default]" } //hidden string to be updated depending on status
sitemap
Text label="Garage" icon="garage"
		Frame label="Control"
		Switch item=GarageDoor label="Garage Door" icon="garagedoor"
		Frame label="Status"
		Text item=GarageDoorState label="[%s]" icon="garagedoor" valuecolor=[GarageDoorState=="Closed"="green",GarageDoorState=="Open"="red",GarageDoorState=="Ajar"="orange"]
		Text label="Settings" icon="settings"
		Switch item=GarageDoorAuto icon="time"
rules
var Timer garageDoorTimer
var Timer garageDoorOpenTimer
//*************************************************************************** Garage Door Rules Below********************************************************************
rule "Garage Door Open"
	Item GarageDoor received command UP
if (garageDoorTimer !== null)
	garageDoorTimer.cancel
	garageDoorTimer = null
	if (GarageDoorOpened.state != ON)
		GarageDoorSwitch.sendCommand(ON)
			garageDoorTimer = createTimer(now.plusSeconds(25)) [|
			if (GarageDoorOpened.state != ON && GarageDoorClosed.state == ON)
rule "Garage Door Close"
	Item GarageDoor received command DOWN
if (garageDoorOpenTimer !== null)
	garageDoorOpenTimer.cancel
	garageDoorOpenTimer = null
	if (GarageDoorClosed.state != ON)
			if (GarageDoorClosed.state != ON && GarageDoorOpened.state == ON)
rule "Garage Door Stop"
	Item GarageDoor received command STOP
	if (GarageDoorClosed.state != ON && GarageDoorOpened.state != ON)
rule "Garage Door State"
	Item GarageDoorClosed received update	or
	Item GarageDoorOpened received update
Thread.sleep(500)
	if (GarageDoorClosed.state == ON && GarageDoorOpened.state == OFF)
		GarageDoor.postUpdate(DOWN)
		GarageDoorState.postUpdate("Closed")
	if (GarageDoorOpened.state == ON && GarageDoorClosed.state == OFF)
		GarageDoor.postUpdate(UP)
		GarageDoorState.postUpdate("Open")
	if (GarageDoorClosed.state == OFF && GarageDoorOpened.state == OFF)
		GarageDoor.postUpdate(50)
		GarageDoorState.postUpdate("Ajar")
rule "Garage Door Button Timer"
	Item GarageDoorSwitch received command ON
	createTimer(now.plusSeconds(1)) [|
	GarageDoorSwitch.sendCommand(OFF)
rule "Garage Door Auto Close"
	Time cron "0 0/6 21-5 1/1 * ? *"
if (GarageDoorAuto.state == ON)
		sendBroadcastNotification("Garage door will shut in 5 minutes")
		garageDoorOpenTimer=createTimer(now.plusMinutes(5)) [|
		sendBroadcastNotification("Garage door has closed automatically")
		GarageDoor.sendCommand(DOWN)
rule "Garage Door Auto Close Switch "
	Item GarageDoorAuto received command OFF
rule "Garage Door Opening"
	Item GarageDoorClosed changed from ON to OFF
	sendBroadcastNotification("Garage Door has opened!")
rule "Garage Door Closing"
	Item GarageDoorOpened changed from ON to OFF
Thread::sleep(500)
	sendBroadcastNotification("Garage Door is Closing!")
Basically. I have a switch which literally sends the MQTT command,
I use a ruller shutter item to have UP X DOWN as commands.
I then run rules to check if the garage is down, and i press down, nothing happens, If the garage is up and i press up, nothing happens. And the X button only works if the garage is neither opened of closed.
I also have 2 reed switches, one for open, one for close.
I have another rule. which when i press either up or down, it sends the command to activate the garage. if after 25 seconds, it hasn’t activated the reed switch i wanted, (either opened or closed depending what i pressed), it will press the garage button one time. If for instance, there is something blocking the door from moving, it wont run the rule again, as I pressed the garage button, not pressed up/down again.
I also have timers, and auto closing after certain times. as you can see in my rules
