I purchased a Yale YRD210 as I saw it already in the ZWave database in habmin product explorer. I am able to get it joined to my Raspberry Pi with the Z-Stick Gen-5 controller. In Habmin it shows up as Node5 but the Value is "Yale Locks [ID:0,Type:4]. In my logs I see this is an unknown device. How can I modify the Value of the node to match what is in the database, or Product Explorer tab of Habmin?
Currently running openHab 1.8.2 with Z-Wave 1.8.0 and Habmin 1.7.0.
This is not supported in the current binding since at the moment security classes are not incorporated. This might change soon, but that’s the current situation
Ok, perhaps I am looking at this wrong. Are you stating the secure command classes are not incorporated, or just any device for security (locks, etc) are not incorporated?
I checked these locations, to see if it uses secure command classes, and both show unsecure supported, secure not supported.
Ok, bummer. I thought the issue with locks was the secure/non-secure messaging and not the entire security command class. I should have done more homework before purchasing. Thanks for the clarification.
I am back up and running on Openhab2 and have started to attempt this again. However I cannot get the YRD210 to securely connect. I have deleted from Z-Wave controller, deleted from “items” and also factory reset the unit. Every time it is included in the Z-Wave network as node12, but it is not using security. I see the password is set in the controller by default. Do I need to change that? Also note the lock is less than 6" from Zwave controller. I just updated to the latest June 11 2017 Zwave build this morning.
