How to stop: Feature named 'openhab-ui-dashboard/0' is not installed in openhab.log
I spoke too soon.
When I make a change in any rule, I get the following error. When I restart openHAB, the original error comes back.
If I delete all the rules, restart, and then add one simple rule, I get the error below again (I thought it might be a rule causing problems).
I really don’t want to start from scratch for a third time - there are always things that need tweaking. The behaviour is never consistent upon start up so if I add, for example, one binding at a time and restart, I’m never going to know whether that caused the problem or not.
My system is screwed and I don’t know what to do.
Here’s the rule editing error (or adding one rule from no rules also starts it):
2020-01-16 15:44:44.572 [ERROR] [xbase.resource.BatchLinkableResource] - resolution of uriFragment '|::0.2.1.2.0.0.1.0.0.6.0::0::/1' failed.
	at org.eclipse.smarthome.model.script.ScriptServiceUtil.getActionServices(ScriptServiceUtil.java:111) ~[?:?]
	at org.eclipse.smarthome.model.script.scoping.ActionClassLoader.loadClass(ActionClassLoader.java:37) ~[?:?]
	at java.lang.Class.forName0(Native Method) ~[?:1.8.0_222]
	at java.lang.Class.forName(Class.java:348) ~[?:1.8.0_222]
	at org.eclipse.xtext.common.types.access.impl.ClassFinder.forName(ClassFinder.java:41) ~[?:?]
	at org.eclipse.xtext.common.types.access.impl.ClassFinder.forName(ClassFinder.java:15) ~[?:?]
	at org.eclipse.xtext.common.types.access.impl.AbstractClassFinder.forName(AbstractClassFinder.java:43) ~[?:?]
	at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.findClassByName(ReflectionTypeProvider.java:155) ~[?:?]
	at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.doFindTypeByName(ReflectionTypeProvider.java:116) ~[?:?]
	at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.findTypeByName(ReflectionTypeProvider.java:109) ~[?:?]
	at org.eclipse.xtext.common.types.xtext.AbstractTypeScope.getSingleElement(AbstractTypeScope.java:59) ~[?:?]
	at org.eclipse.xtext.common.types.xtext.AbstractTypeScope.getSingleElement(AbstractTypeScope.java:54) ~[?:?]
	at org.eclipse.xtext.common.types.xtext.AbstractTypeScope.getElements(AbstractTypeScope.java:73) ~[?:?]
	at org.eclipse.xtext.scoping.impl.AbstractScope.getElements(AbstractScope.java:137) ~[?:?]
	at org.eclipse.xtext.scoping.impl.ScopeBasedSelectable.getExportedObjects(ScopeBasedSelectable.java:40) ~[?:?]
	at org.eclipse.xtext.scoping.impl.ImportScope.getLocalElementsByName(ImportScope.java:154) ~[?:?]
	at org.eclipse.xtext.scoping.impl.ImportScope.getSingleLocalElementByName(ImportScope.java:142) ~[?:?]
	at org.eclipse.xtext.scoping.impl.AbstractScope.getSingleElement(AbstractScope.java:105) ~[?:?]
	at org.eclipse.xtext.scoping.impl.AbstractScope.getSingleElement(AbstractScope.java:108) ~[?:?]
	at org.eclipse.xtext.xbase.scoping.batch.TypeLiteralScope.getLocalElementsByName(TypeLiteralScope.java:48) ~[?:?]
	at org.eclipse.xtext.xbase.scoping.batch.AbstractSessionBasedScope.getElements(AbstractSessionBasedScope.java:174) ~[?:?]
	at org.eclipse.xtext.xbase.scoping.batch.AbstractSessionBasedScope$1.get(AbstractSessionBasedScope.java:180) ~[?:?]
	at org.eclipse.xtext.xbase.scoping.batch.AbstractSessionBasedScope$1.get(AbstractSessionBasedScope.java:177) ~[?:?]
	at org.eclipse.xtext.scoping.impl.AbstractScope$ParentIterable.iterator(AbstractScope.java:60) ~[?:?]
	at com.google.common.collect.FluentIterable$3$1.get(FluentIterable.java:296) ~[bundleFile:?]
	at com.google.common.collect.FluentIterable$3$1.get(FluentIterable.java:293) ~[bundleFile:?]
	at com.google.common.collect.AbstractIndexedListIterator.next(AbstractIndexedListIterator.java:77) ~[bundleFile:?]
	at com.google.common.collect.Iterators$ConcatenatedIterator.hasNext(Iterators.java:1330) ~[bundleFile:?]
	at com.google.common.collect.Iterators$5.computeNext(Iterators.java:635) ~[bundleFile:?]
	at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:141) ~[bundleFile:?]
	at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:136) ~[bundleFile:?]
	at com.google.common.collect.Iterators$ConcatenatedIterator.hasNext(Iterators.java:1321) ~[bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.getLinkingCandidates(AbstractTypeComputationState.java:412) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:1226) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer.computeTypes(XbaseTypeComputer.java:112) ~[?:?]
	at org.eclipse.smarthome.model.script.jvmmodel.ScriptTypeComputer.computeTypes(ScriptTypeComputer.java:38) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.doComputeTypes(AbstractTypeComputationState.java:121) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.computeTypes(AbstractTypeComputationState.java:109) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState$1.getActualType(AbstractTypeComputationState.java:403) ~[?:?]
	at org.eclipse.xtext.xbase.scoping.batch.FeatureScopes.createFeatureCallScopeForReceiver(FeatureScopes.java:215) ~[?:?]
	at org.eclipse.xtext.xbase.scoping.batch.FeatureScopes.createFeatureCallScope(FeatureScopes.java:92) ~[?:?]
	at org.eclipse.xtext.xbase.scoping.batch.AbstractFeatureScopeSession.createFeatureCallScope(AbstractFeatureScopeSession.java:177) ~[?:?]
	at org.eclipse.xtext.xbase.scoping.batch.AbstractFeatureScopeSession.getScope(AbstractFeatureScopeSession.java:48) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.ScopeProviderAccess.getCandidateDescriptions(ScopeProviderAccess.java:142) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.getLinkingCandidates(AbstractTypeComputationState.java:409) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:254) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer.computeTypes(XbaseTypeComputer.java:132) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:491) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer.computeTypes(XbaseTypeComputer.java:118) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractRootTypeComputationState.computeTypes(AbstractRootTypeComputationState.java:32) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:827) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:711) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeMemberTypes(LogicalContainerAwareReentrantTypeResolver.java:897) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:886) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:705) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:697) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:164) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:139) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.resolveTypes(CachingBatchTypeResolver.java:80) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:57) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:53) ~[?:?]
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37) ~[bundleFile:?]
	at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:128) ~[bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.doResolveTypes(CachingBatchTypeResolver.java:53) ~[bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:69) ~[bundleFile:?]
	at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:60) ~[bundleFile:?]
	at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:41) ~[bundleFile:?]
	at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getEObject(BatchLinkableResource.java:117) ~[bundleFile:?]
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223) ~[bundleFile:?]
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:199) ~[bundleFile:?]
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:259) ~[bundleFile:?]
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1477) ~[bundleFile:?]
	at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImplCustom.getFeature(XAbstractFeatureCallImplCustom.java:48) ~[?:?]
	at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImplCustom.isStatic(XAbstractFeatureCallImplCustom.java:151) ~[?:?]
	at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImplCustom.getActualArguments(XAbstractFeatureCallImplCustom.java:180) ~[?:?]
	at org.eclipse.xtext.xbase.impl.XFeatureCallImplCustom.getActualArguments(XFeatureCallImplCustom.java:39) ~[?:?]
	at org.eclipse.xtext.xbase.controlflow.DefaultEarlyExitComputer._exitPoints(DefaultEarlyExitComputer.java:244) ~[?:?]
	at org.eclipse.xtext.xbase.controlflow.DefaultEarlyExitComputer.exitPoints(DefaultEarlyExitComputer.java:308) ~[?:?]
	at org.eclipse.xtext.xbase.controlflow.DefaultEarlyExitComputer.getExitPoints(DefaultEarlyExitComputer.java:65) ~[?:?]
	at org.eclipse.xtext.xbase.controlflow.DefaultEarlyExitComputer._exitPoints(DefaultEarlyExitComputer.java:247) ~[?:?]
	at org.eclipse.xtext.xbase.controlflow.DefaultEarlyExitComputer.isEarlyExit(DefaultEarlyExitComputer.java:48) ~[?:?]
	at org.eclipse.xtext.xbase.validation.EarlyExitValidator.checkDeadCode(EarlyExitValidator.java:105) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_222]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_222]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator$MethodWrapper.invoke(AbstractDeclarativeValidator.java:127) ~[bundleFile:?]
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator.internalValidate(AbstractDeclarativeValidator.java:318) ~[bundleFile:?]
	at org.eclipse.xtext.validation.AbstractInjectableValidator.validate(AbstractInjectableValidator.java:71) ~[bundleFile:?]
	at org.eclipse.xtext.validation.CompositeEValidator.validate(CompositeEValidator.java:150) ~[bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.doValidate(Diagnostician.java:171) ~[bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:158) ~[bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:137) ~[bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:185) ~[bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:161) ~[bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:181) ~[bundleFile:?]
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:108) ~[bundleFile:?]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.lambda$2(ModelRepositoryImpl.java:290) ~[bundleFile:?]
	at org.eclipse.smarthome.model.core.internal.SafeEMFImpl.call(SafeEMFImpl.java:30) [bundleFile:?]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.validateModel(ModelRepositoryImpl.java:290) [bundleFile:?]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:103) [bundleFile:?]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:247) [bundleFile:?]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:310) [bundleFile:?]
	at org.eclipse.smarthome.core.service.WatchQueueReader.run(WatchQueueReader.java:240) [bundleFile:?]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Are you using IPv6? That error looks like it might contain an IPv6 address.
No, I believe I am using IPv4. How do I check?
HABpanel is behaving itself again but I still get the dashboard debug message every minute.
That would be OS specific. I scanned your posts quickly and missed that information. I wonder if the OS is set to permit IPv6 too and that needs to be disabled. I think most OSs have it turned on by default.
I’ve got a Rasberry PI 3+ running openhabian and now openHAB 2.5.1. from a SSD.
If you installed from an image, that OS is basically Raspbian Lite. I will not be home until Sunday so I cannot check my Pi but you may find answers in a Pi forum to the IPv6 questions.
I was also getting this error on RPi running 2.5.1. Paper UI and Habmin showed Dashboard 2.5.1 as being installed, but couldn’t uninstall it.
I had tried to uninstall it using Paper UI when I upgraded from 2.4 to 2.5.1 last week, but I forget if I did the uninstall before or after the upgrade. I think it was left in some sort of half-installed broken state. bundle:list and feature:list showed it running, but couldn’t uninstall it. There were no references to it in add-ons.cfg or addons.config, and its tile didn’t show up in the web interface.
I edited /var/lib/openhab2/config/org/openhab/addons.config and added dashboard back:
ui="dashboard,basic,paper,habpanel,habmin"
Dashboard still doesn’t work and I still can’t uninstall it (because 2.5.1 was never installed and the previous version was uninstalled incompletely), but scheduled sync is no longer trying to uninstall it and the errors have stopped.
You can disable IPv6 by adding
net.ipv6.conf.all.disable_ipv6=1
to /etc/sysctl.conf and run sudo sysctl -p to enable it.
I noticed in /var/lib/openhab2/etc/profile.cfg
feature.openhab-ui-dashboard = openhab-ui-dashboard
feature.openhab-ui-dashboard/2.5.1 = openhab-ui-dashboard/2.5.1
Consequently, there were also two entries in config/profile.config.
Commented the first line out, restarted, et voilà.
As a bonus, I noticed there were also
feature.openhab-runtime-base = openhab-runtime-base
feature.openhab-runtime-base/2.5.0 = openhab-runtime-base/2.5.0
While I didn’t see error messages about restarts of that, I also commented out the first of those lines.
OH keeps working. Not 100% sure but I think it’s using less CPU now.
I had already tried that. It didn`t solve the problem. I just tried it again. Still no luck.
I tried various combinations of what you did. I just tried something that I am sure I tried before and that was to change addons config package from minimal to standard and comment out the UI = line.
Last time I did this, I’m sure I lost the dashboard but doing it this time, I have the dashboard items back and the ‘every-minute’ debug message is:
[DEBUG] [core.karaf.internal.FeatureInstaller] - Running scheduled sync job
I upgraded to the latest snapshot last night and the multitude of non-stop errors when I edited the rules files seems to have disappeared so that may not have been related to my other problems.
I take it the ‘Running scheduled sync job’ debug message is not normal behaviour - or is it - can anyone confirm?
Setting org.openhab.core.karaf logging to trace does not give me any more information on this.
Thanks for everyone’s help!
I get that “Running scheduled sync job” message too, but I assume it’s normal behavior.
Strangely, I tried replicating the solution posted by @mstormi but as soon as I removed it from my addons.config the error came back.
Maybe you just made a type (as I did, now corrected) but you must edit *.cfg files (those in /var/lib/openhab2/etc). *.config files in /var/lib/openhab2/config are generated.
@Bruce_Osborne and @noppes123, these days it’s more like that disabling IPv6 gives you more problems. But if disabling it resolves problems, then you should take a look at other parts of your network and networks you are connected to and hopefully upgrade them. IPv6 is the one we should prefer.
Sorry for the off topic.
Some of out Internet service providers do not yet do IPv6 so we are stuck with IPv4.. :face_with_symbols_over_mouth: :frowning:
I really can’t understand how this is still possible. Only problem with my isp is not properly supported prefix delegation in 4g networks.
In the US? Sure. unfortunately. They have a monopoly in our area. :frowning:
Most ISP’s have limited support for IPv6 so sticking with IPv4 is a good choice for now.
When IPv6 was designed/defined, ‘they’ forgot to define a decent migration approach. That’s why most ISP’s still struggle with it.
