How to transform mqtt data from sonoff pir sensor
Hi
Is there someone that can explain how to transform data from a pir sensor
I would like to understand how to do it as I have a lot of different sensors that I want to do . this is an example of the data that I get from one of the sensors
{“RfReceived”:“Sync”:12490,“Low”:420,“High”:1220,“Data”:“D3869E”,“RfKey”:“None”}}
Thank you
That’s JSON data, so you could look into the use of JSONPATH transformation service with MQTT channels. Lots of Tasmota and sonoff examples in this forum.
Hi
Thank you very much for your reply .I did it with rules on the rf bridge but the 3 rule bukkets are full and I still have 5 sensors to do and 2 x 4 button remotes I do use conf files
Regards
Lukas
Not sure what you mean by that?
each rule buffer can take 511 characters and there is only 3
