How to trigger motion on zwave
i’m triing to trigger motion on a rule:
rule “Calculate Monthly Charge”
Item cucinaMotion received update
var HSBType luce = new HSBType(new DecimalType(181),new PercentType(20),new PercentType(100))
LuceCucina.sendCommand(luce)
But it doesn’t work.
Someone has the same problem?
Bye
What device are you using? Is there anything in the logs? Does the item update ok in the UI (if not then the rule won’t run).
It’s really hard to say what is happening without some more information - it might be that the device is using the NOTIFICATION class that isn’t well supported yet, or it might be that associations aren’t configured, or it might be something else…
