can you unexpose an item from openhab cloud
i exposed an item that is no longer needed
where is that located i never saw that when setting up i did use text files
PaperUI β Configuration β Services β IO β OpenHAB Cloud β Configure
Remove your items in /services/openhabcloud.cfg
from the expose=
line
If you did not find the docs yet: itβs all in there:
https://docs.openhab.org/addons/ios/openhabcloud/readme.html
oh just remove the exposed item from the file i thought there would be a command like unexpose i assumed once exposed that was just exposed i will look now thanks for that sihui
I have looked and found where thats located, i also read the docs you sent me when i set this up the other week that part wasent there when i read it the docs must have been recently updated
Thanks for that m8
