Hi All
I am embarking on setting up openHAB to run a basic irrigation system. I have an old Raspberry Pi 2B and a Denkovi USB 8 channel relay board. I have OpenHAB 2 running on the RPi and can see this is going to be a long journey for a beginner - however we’ll get there.
The relay board will not natively integrate to OpenHAB but has a command line tool which I intend to use with the exec binding - more pain (and questions) to come there later.
The tool requires the commands "rmmod ftdi_sio" and "rmmod usbserial" be run as sudo to unload the respective drivers, which i presume cause problems with using the board on any linux system.
I cannot work out how to have openhabian do this automatically on every start up - though I presume (and hope!) it is simple??? It seems the blacklist file was the way to do this but has since been removed from raspbian - which I understand openhabian is based on?
Any help on how to do this would be greatly appreciated.
