I have been running v2.1.0 and would like to upgrade to v2.2.0. The installation is in a FreeBSD jail and I simply unzip the Openhab package and run from there. I have unzipped 2.2.0 package, what files should i copy from 2.1.0 into the 2.2.0 folder?
I have copied over the conf folder to the v2.2.0. But how do i get the things copied over?
root@openhab:/home/openhab # openhab2/runtime/bin/update
openHAB 2.x.x update script
The script must be called from openHAB's root directory.
Either specify a directory or place this update script in and run from openHAB's root folder.
root@openhab:/home/openhab # cd openhab2/
root@openhab:/home/openhab/openhab2 # runtime/bin/update
Making Temporary Directory
Downloading openHAB 2.2.0...
######################################################################## 100.0%
Update script in .zip archive found, using that instead.
The script will attempt to update openHAB to version 2.2.0
Is this okay? [y/N]: y
Removing openHAB System Files...
mv: rename /usr/home/openhab/openhab2/userdata/etc/custom.system.properties to /tmp/openhab/userdata/etc/custom.system.properties: No such file or directory
Clearing cache...
Updating openHAB...
Found an openHAB addons file, replacing with new version...
Deleting temporary files...
Restoring previous file ownership (openhab:openhab)
SUCCESS: openHAB updated from 2.1.0 to 2.2.0
