I have a running OH-Test-System with NGRE, Jython and Helper-Libraries, which I setup early this year to
rewrite my DSL-Rules into Python-Scripts and meanwhile all my Rules are running more or less as Python-Scripts.
I used the Docs — https://openhab-scripters.github.io/openhab-helper-libraries/Getting%20Started/Installation.html — and worked thru step by step
But in the meantime, I think, there are a lot of changes. The OH-System is now 2.5.6 . But I think that the NGRE/Jython-Part
didn’t get such automatic Updates
Somewhere in the forum I have read that OH/NGRE/Jython runs with JAVA 11 but also have read that it doesnt, so I tried it for my own risk.
… and it doesn’t work, but it was no problem to set (roll) back. What I learned, it seems as if the DSL-Part seems to run,
but not the Jython-Part.
So I want to ask if there is someone who can explain me, how to upgrade my System.
Here is some system-information about it:
- ======================================== my_sysinfo - Start ========================================================
- ******* Hardware-Info = Model : Raspberry Pi 3 Model B Rev 1.2
- ******* Hardware-Info = model name: ARMv7 Processor rev 4 (v7l)
- =========================================== Linux Version ==========================================================
- ******* Linux-Version-Info = Raspbian GNU/Linux 10 (buster) (Pretty-Name)
- ===================================== Openhab-Version Info =========================================================
- ******* OH-Version-Info = openHAB Distribution Version Information
- ******* OH-Version-Info = ----------------------------------------
- ******* OH-Version-Info = build-no : Release Build
- ******* OH-Version-Info = online-repo : https://openhab.jfrog.io/openhab/libs-release
- ******* OH-Version-Info = Repository Version
- ******* OH-Version-Info = openhab-distro : 2.5.6
- ******* OH-Version-Info = openhab-core : 2.5.0
- ******* OH-Version-Info = openhab1-addons : 1.14.0
- ******* OH-Version-Info = openhab2-addons : 2.5.6
- ******* OH-Version-Info = karaf : 4.2.7
- ===================================== Jython-Parameters (Scott) ==================================================
- ******* Jython-Version = 2.7.0.final
- ******* os.name = Linux
- ******* os.version = 4.19.118-v7+
- ******* java.vendor = Azul Systems, Inc.
- ******* java.vm.name = OpenJDK Client VM
- ******* java.runtime.name = OpenJDK Runtime Environment
- ******* java.runtime.version = 1.8.0_252-b225
- ******* sys.path = /etc/openhab2/automation/lib/python
/etc/openhab2/automation/jython/Lib
/etc/openhab2/automation/jython/jython-standalone-2.7.0.jar/Lib
__classpath__
__pyclasspath__/
- ******* java.external.dirs = /opt/jdk/zulu8.46.0.225-ca-jdk8.0.252-linux_aarch32hf/jre/lib/ext:/opt/jdk/zulu8.46.0.225-ca-jdk8.0.252-linux_aarch32hf/lib/ext:/usr/share/openhab2/runtime/lib/ext
- ******* user.name = hansdampf
- ******* file.encoding = UTF-8
- ******* jetty.host = 0.0.0.0
- ======================================== my_sysinfo - End =========================================================
and some tree information about the automation-folder:
[01:36:27] hab@ohtest:/etc/openhab2/automation$ tree
├── jsr223
│ └── python
│ ├── community
│ │ └── README.md
│ ├── core
│ │ ├── 000_startup_delay.py
│ │ └── components
│ │ ├── 100_DirectoryTrigger.py
│ │ ├── 100_OsgiEventTrigger.py
│ │ ├── 100_StartupTrigger.py
│ │ ├── 200_JythonBindingInfoProvider.py
│ │ ├── 200_JythonExtensionProvider.py
│ │ ├── 200_JythonItemChannelLinkProvider.py
│ │ ├── 200_JythonItemProvider.py
│ │ ├── 200_JythonThingProvider.py
│ │ ├── 200_JythonThingTypeProvider.py
│ │ └── 200_JythonTransform.py
│ └── personal
│ ├── astro_events_test.py
│ ├── astro_moon_orbit.py
│ ├── avm_status.py
│ ├── bluetooth.py
│ ├── cpu_monitor.py
│ ├── hello_world.py_stopped
│ ├── monitoring_window_door.py
│ ├── ntp.py
│ ├── owm_list.py
│ ├── owm_test_scott.py
│ ├── owm_wind.py
│ ├── presence_detection.py
│ ├── README.md
│ ├── tasmota_http.py
│ ├── tasmota_status_refresh.py
│ ├── test_date.py
│ ├── test_syspath_check.py
│ ├── test_update.py
│ └── untitled_1.py
├── jython
│ └── jython-standalone-2.7.0.jar
└── lib
└── python
├── community
│ ├── __init__$py.class
│ └── __init__.py
├── configuration$py.class
├── configuration.py
├── core
│ ├── actions$py.class
│ ├── actions.py
│ ├── date$py.class
│ ├── date.py
│ ├── __init__.py
│ ├── items$py.class
│ ├── items.py
│ ├── jsr223$py.class
│ ├── jsr223.py
│ ├── links$py.class
│ ├── links.py
│ ├── log$py.class
│ ├── log.py
│ ├── metadata$py.class
│ ├── metadata.py
│ ├── osgi
│ │ ├── events$py.class
│ │ ├── events.py
│ │ ├── __init__$py.class
│ │ └── __init__.py
│ ├── rules$py.class
│ ├── rules.py
│ ├── testing.py
│ ├── triggers$py.class
│ ├── triggers.py
│ ├── utils$py.class
│ └── utils.py
└── personal
└── __init__.py
13 directories, 68 files
Is there anyone to help me and explain me in simple words if it is neccessary and how to upgrade ?
Thx in advance - Peter
