- Platform information:
- Hardware: raspi3
- OS: openhabian
- Java Runtime Environment:
openjdk version “11.0.12” 2021-07-20 LTS
OpenJDK Runtime Environment Zulu11.50+19-CA (build 11.0.12+7-LTS)
OpenJDK Client VM Zulu11.50+19-CA (build 11.0.12+7-LTS, mixed mode) - openHAB version: 3.2 M2
- Issue of the topic: Can someone help me understand if it is possible to define somwhere in OH3 GUI profiles for channels such as:
rawrocker-to-on-off or rawbutton-on-off-switch
I want to achieve exactly like on doc Items | openHAB with this sample:
channel="serialbutton:button:mybutton:button" [profile="system:rawbutton-toggle-switch"]
I was using oh 1.x 2.x and had all in txt files- that works. in OH3 I try to do not touch config files just keep GUI. But I can’t see such profiles when linking channels to Items (just only transformation ones or timestamp). IS IT SUPPORTED already?
I added also item using text editor available in GUI, I defined profile over there but after saving I’m not sure how to check if profile is still attached to this Item? What if I edit Item in GUI later and press save, Is it going to overwrite profile?
