I have a 24V power supply (on a KNX actor) that I want to switch off if no lights (on DALI) are on. So I have made the following items:
Group:Dimmer:MAX g24Volt
Dimmer Licht_LED1 "Lichtleiste A [%d %%]" (g24Volt) { knx="1/1/1,1/1/2,1/1/3+1/1/4" }
Dimmer Licht_LED2 "Lichtleiste B [%d %%]" (g24Volt) { knx="1/1/5,1/1/6,1/1/7+1/1/8" }
and this rule
rule "rTrafoAusEin"
Item g24Volt changed
if (g24Volt.state > 0 ) {
Licht_Trafo.sendCommand(ON)
} else {
Licht_Trafo.sendCommand(OFF)
But the rule never gets executed. I do not see my mistake? Can anybody spot the error?
