Sharpy
(Aaron Sharp)
June 10, 2018, 12:40pm
1
Hi everyone
How do you close kodi running on a firestick using the kodi binding channel send system command
Sending the shutdown command too kodi on Windows I get the expected response kodi closes system shutdown
Sending the same command too kodi on firestick nothing happens
cweitkamp
(Christoph Weitkamp)
June 11, 2018, 1:18pm
2
Hi Aaron,
I am afraid that is not possible. You are not allowed to “shutdown” a Fire TV Stick or an Android OS from Kodi. You have to use the “Quit” method which is not supported by the binding.
Sharpy
(Aaron Sharp)
June 11, 2018, 1:20pm
3
Hi again Christoph
Is there a plan too add quit too the binding or is it just not possible ?
cweitkamp
June 11, 2018, 1:58pm
4
Not yet. Feel free to open a feature request in OH2 repo.
emilbauer
(Emil Bauer)
November 1, 2018, 9:13pm
5
I just found this: Control your Amazon Fire TV (or every Android Device) from openHAB
maybe sending a “Homebutton” command would work for you?
Sharpy
(Aaron Sharp)
November 1, 2018, 11:02pm
6
I just gave up recently with the firestick for a kodi device
I have moved too a RPI 3 B+ Running LibreELEC but thanks for the suggestion
cweitkamp
November 2, 2018, 11:44am
7
Hi all,
regardless if you need it or not, I have implemented a solution for it . It was on my to-do list anyways and I need it too.
Sharpy
(Aaron Sharp)
November 2, 2018, 1:21pm
8
Nice work thanks for that the reason I moved away from the firestick for kodi was many not because of openhab
This device was for my kids for kodi only and the firestick was not appropriate i needed a device i had more controll over
I Still have the firestick might give it a try it’s ok for an adult device
