OK
log:
2023-02-11 14:00:14.736 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ESP8266_Wieza_IR_polecenia' received command MUTE
2023-02-11 14:00:14.737 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ESP8266_Wieza_IR_polecenia' predicted to become {"IRSend":"Invalid RawData"}
2023-02-11 14:00:17.231 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '{"IRSend":"Invalid RawData"}' with the file 'ir_wieza.map' : Target value not found in map for '{"IRSend":"Invalid RawData"}'
2023-02-11 14:00:18.436 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ESP8266_Wieza_IR_polecenia' received command ON
2023-02-11 14:00:18.438 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ESP8266_Wieza_IR_polecenia' predicted to become {"IRSend":"Invalid RawData"}
MAP file
ON = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA802080A0","DataLSB":"0x435301040105","Repeat":0}
OFF = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA802080A0","DataLSB":"0x435301040105","Repeat":0}
MUTE = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA80209C08","DataLSB":"0x435301043910","Repeat":0}
VOLUP = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020CC50","DataLSB":"0x43530104330A","Repeat":0}
VOLDOWN = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020DC48","DataLSB":"0x435301043B12","Repeat":0}
CHUP = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020C490","DataLSB":"0x435301042309","Repeat":0}
CHDOWN = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020D488","DataLSB":"0x435301042B11","Repeat":0}
ENTER = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020A090","DataLSB":"0x435301040509","Repeat":0}
EQ = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA80202890","DataLSB":"0x435301041409","Repeat":0}
TIMER_ONOFF = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA80204AD0","DataLSB":"0x43530104520B","Repeat":0}
TIMER_CLOCK = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA80206AF0","DataLSB":"0x43530104560F","Repeat":0}
SLEEP = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA802084E0","DataLSB":"0x435301042107","Repeat":0}
REPEAT = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA80208E30","DataLSB":"0x43530104710C","Repeat":0}
MONO_STEREO = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020AC30","DataLSB":"0x43530104350C","Repeat":0}
TUNING_MODE = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020F488","DataLSB":"0x435301042F11","Repeat":0}
RW = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA80204630","DataLSB":"0x43530104620C","Repeat":0}
FF = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA80200ED0","DataLSB":"0x43530104700B","Repeat":0}
PLAY = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020C0E0","DataLSB":"0x435301040307","Repeat":0}
PREV = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020D808","DataLSB":"0x435301041B10","Repeat":0}
NEXT = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020C810","DataLSB":"0x435301041308","Repeat":0}
STOP = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA8020D0F8","DataLSB":"0x435301040B1F","Repeat":0}
USB_REC = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA80204060","DataLSB":"0x435301040206","Repeat":0}
NEXT_10 = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA80201EC8","DataLSB":"0x435301047813","Repeat":0}
FUNCTION = {"Protocol":"PANASONIC","Bits":48,"Data":"0xC2CA802090B8","DataLSB":"0x43530104091D","Repeat":0}
thing
UID: mqtt:topic:8862487c38:aecb111100
label: ESP8266 Wieża IR
thingTypeUID: mqtt:topic
configuration:
payloadNotAvailable: Offline
availabilityTopic: tele/tasmota_IR2_wieza/LWT
payloadAvailable: Online
bridgeUID: mqtt:broker:8862487c38
channels:
- id: ESP_IR_Wieza_Samsung_Tasmota
channelTypeUID: mqtt:string
label: Bramka BLE Online
description: null
configuration:
postCommand: false
retained: false
formatBeforePublish: "%s"
stateTopic: tele/tasmota_IR2_wieza/LWT
- id: ipaddress
label: IPAddress
description: null
configuration:
postCommand: false
retained: false
stateTopic: tele/tasmota_IR2_wieza/INFO2
transformationPattern: JSONPATH:$.IPAddress
- id: Wieza_Samsung_IR_CMD
label: Wieża Samsung IR CMD
description: null
configuration:
commandTopic: cmnd/tasmota_IR2_wieza/IRSend
postCommand: true
retained: false
stateTopic: stat/tasmota_IR2_wieza/RESULT
