I read a lot in the last days abaout zigbee and zigbee2mqtt and how to add devices to openhab. But i cant get my sonof door / window sensor to work. i install MQTT Binding and it works as Bridge with my mosquitto Broker. I do not know where and how i make the logical connection to the device and openHAB. Actually i think its in the Channel and the mqtt state field, but it do not work. I tried mqtt:IEEE Address, or mqtt:device_name, or zigbee2mqtt/ieee address and so on.
What is correct, or where to link the device with openHAB?
Thankx
You create a new generic mqtt thing and point it to the mqtt broker.
Then you add your channels and items for example below:
UID: mqtt:topic:mqttbroker:0bc8c6461a
label: Zigbee door back sensor
thingTypeUID: mqtt:topic
configuration:
payloadNotAvailable: offline
availabilityTopic: zigbee2mqtt/door-back/availability
payloadAvailable: online
bridgeUID: mqtt:broker:mqttbroker
channels:
- id: zigbeedoorback
channelTypeUID: mqtt:contact
description: ""
configuration:
stateTopic: zigbee2mqtt/door-back
transformationPattern: JSONPATH:$.contact
off: "true"
on: "false"
- id: zigbeedoorbackbattery
channelTypeUID: mqtt:number
label: Zigbee door back battery
description: ""
configuration:
transformationPattern: JSONPATH:$.battery
unit: "%"
take note of the jsonpath as you need that so you can extract the data coming in from the device.
Also you need to install the JSONPATH addon.
Either auto-detection (doesnât work well for many devices), UI (as @ubeaut described above) or text file.
While the UI is great for almost anything I still like to define my zigbee2mqtt things in a.thing file. This is because you have to define the channels anyway which makes it quicker (for me).
A good start with many examples is:
This way you donât need JSON transformations anymore as all attributes are sent separately and can be directly attached to a channel.
Here is an example for a smart plug:
Thing mqtt:topic:PlugWaschmaschine "PlugWaschmaschine" (mqtt:broker:MosquittoMqttBroker) { Channels:
Type switch : state "state" [ stateTopic = "zigbee2mqtt/PlugWaschmaschine/state", commandTopic = "zigbee2mqtt/PlugWaschmaschine/set/state", on="ON", off="OFF" ]
Type datetime : last_seen "last_seen" [ stateTopic = "zigbee2mqtt/PlugWaschmaschine/last_seen" ]
Type number : power "power" [ stateTopic = "zigbee2mqtt/PlugWaschmaschine/power" ]
Type number : energy "energy" [ stateTopic = "zigbee2mqtt/PlugWaschmaschine/energy" ]
Type number : current "current" [ stateTopic = "zigbee2mqtt/PlugWaschmaschine/current" ]
You save this as anyName.things under âŠopenHAB-conf/things.
Then I usually create all items with âAdd Equipment to Modelâ that you find in the channel tab of your new thing.
Letâs start with the basics, what is this device you have, brand, model and what firmware is it running on?
the broker is ok, thats what i understand, no problem. But i thought i can configure all in tue ui, but it seems not so, right? Since now i use Homematic Devices and Bridge and thats very simple, so i am a little bit confused to include mqtt Things :).
Sorry, you right, it was late last night and after search the net since houres for a solution, i want to ask quick. So its Sonoff SNZB-04 Door/Windows Sensor with Firmwaredate: 20211103. Its out of the box.
It is all done in the UI.
I donât use files at all.
I just included the code of what I have set up for an example for you.
Watch this from time 4:45 âŠIt is in German but you will get the idea.
I tried it in many ways, but it doesnt work. So i download MQTT Explorer and connect to the Broker, but the Device isnt shown. Any Idea to solve this?
Sorry but without more knowledge about your setup it is very hard to help you. What zigbee controller do you have??
Ok, step by stepâŠ
- Did you setup zigbee2mqtt successfully ? (Should show connection to your broker in the log)
- Did you pair your contact to zigbee2mqtt and is it shown in the z2m dashboard ?
When 1 and 2 are answered with yes, we can move forward to the openHAB part.
yes to both. Mosquitto is installed correct and zigbee2mqtt shows paired device in ui. Logs seems to be ok. I installed Mosquitto and Zigbee2 MQTT on a different host than openHAB. In openHAB the MQTT Bridge is successfull installed and shows Online, also in the Logs.
What do you have in the zigbee2mqtt configuration.yaml for the server ip address?
Mine looks like this:
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.1.164
keepalive: 60
If you have IP address of localhost or 127.0.0.1 you wonât see it on another computer. You will need the actual IP of the server you are running it on and that IP address would be what you use in the mqtt broker in openhab.
If it was all on the one computer you could use the 127.0.0.1
Yes Mosquitto Broker and Zigbee2MQTT is on the same Host. Anywhere tried it with IP-Address, but no change. Host listen on 1883: TCP *:1883 (LISTEN) and OH client can see it: [IP] 1883 (?) open
Published Topic is: MQTT publish: topic 'zigbee2mqtt/DoorWindow, payload â{âbatteryâ:100,âbattery_lowâ:false,âcontactâ:true,âlinkqualityâ:51,âtamperâ:false,âvoltageâ:3100}â
So there seems to be no MQTT State, right?
I created now a new Thing, with no further special settings.
The Channel has:
- State Topic = zigbee2mqtt/0x00
- on Value = false
- off Value = true
- Value Transformation = REGEX:(.contact.)â©JSONPATH:$.contact
If the topic is zigbee2mqtt/DoorWindow then why do you have this as the state topic: zigbee2mqtt/0x00
There is no way that is going to work.
Run this command on a computer that has the mosquitto client change the ip address to your address:
mosquitto_sub -h 192.168.1.164 -v -t "zigbee2mqtt/#"
Then copy and paste the output of the device you are looking at.
Here is what mine looks like:
zigbee2mqtt/door-back {"battery":100,"battery_low":false,"contact":true,"last_seen":"2023-09-11T07:52:26+10:00","linkquality":98,"tamper":false,"voltage":3100}
With all the examples I have provided you should be able to work it out.
Also the state will be the contact of the device once you create an item for that device.
I didnt understand it too. Yes it should be clear after all your help, but it isnt. I run the command and the only thing i see is the friendly name, no data. Topic was a test with uid, friendly name doesnt work too.
What did you run?
What did you see?
Canât help if I donât know what you are doing.
What did you run?
â [mosquitto/zigbee2mqtt host] # mosquitto_sub -v -t âzigbee2mqtt/#â -u -P ââ -h 192.168.0.77 -p 1883
What did you see?
â a lot and âdevicesâ:{â0x00124bxx60câ:{âfriendly_nameâ:âDoorWindowâ}}
â if i search the output for contact, i didnt find expected information
â ofcourse
You have a username and a password on the mqtt broker (zigbee2mqtt).
Why donât you take that off and get it to work and then put it back if needed later?
I donât bother with the username and password. (less hassle)
Up to you but the example I have given you are for NO username or password.
