openHAB Docker Installation Guide
Source: https://github.com/jimtng/openhab-docker-setup
This is a set of step-by-step copy-pasteable instructions to install openHAB as a Docker container, along with:
- Mosquitto MQTT Broker
- Zigbee2MQTT (optional)
This guide works on a clean, minimal install of Ubuntu 24, but it should also work on a working full installation and possibly also on other versions of Debian based Linux.
Contents:
- Expected Outcome
- Install Docker
- Create compose.yml
- Create Directories and Config Files
- Start up the Docker Containers
- Access openHAB’s Web Interface
- Configure Zigbee2MQTT
- More Tips
Expected Outcome
- Docker and its dependencies installed
- 3 docker containers created
openhabmosquittozigbee2mqtt
- The containers will run under your UID and GID. This is to make it easier to manage file permissions inside and outside the containers.
- Directories / Files created:
compose.ymlopenhab/conf/- the main openHAB’s configuration folder, often referred to as$OPENHAB_CONFuserdata/- this is openHAB’s internal storage for your instance, often referred to as$OPENHAB_USERDATAaddons/- this is where you can put custom add-on jar files to load into openHAB
mosquitto/mosquitto.conf
zigbee2mqtt/configuration.yaml
- Your unix user will be included in the
dockergroup - Zigbee2MQTT will not be fully configured yet. You’ll need to finish configuring it to connect your Zigbee dongle.
The commands in this guide will not overwrite your existing files, so if something isn’t working, ensure that the file contents are correct.
If you don’t need/use Zigbee, edit compose.yml and remove the zigbee section.
Install Docker
The following instructions were copied from https://docs.docker.com/engine/install/ubuntu/#install-using-the-repository
# Add Docker's official GPG key:
sudo apt-get update
sudo apt-get install ca-certificates curl
sudo install -m 0755 -d /etc/apt/keyrings
sudo curl -fsSL https://download.docker.com/linux/ubuntu/gpg -o /etc/apt/keyrings/docker.asc
sudo chmod a+r /etc/apt/keyrings/docker.asc
# Add the repository to Apt sources:
echo \
"deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/ubuntu \
$(. /etc/os-release && echo "${UBUNTU_CODENAME:-$VERSION_CODENAME}") stable" | \
sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt-get update
# Install the latest Docker version
sudo apt-get install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin
Docker post install steps
# Create the docker group if it does not exist
getent group docker || sudo groupadd docker
# add the current user to the docker group
sudo usermod -aG docker $USER
# Load the new group
newgrp docker
Then do the next command to revert the main group back.
newgrp
[ $(id -u) == $(id -g) ] || echo "Warning: the current gid doesn't match your uid. Don't proceed. Try rebooting."
Create compose.yml
GID=$(id -g)
[ -f compose.yml ] && echo Warning: compose.yml already exists || cat <<EOF > compose.yml
services:
openhab:
image: openhab/openhab:latest
# image: openhab/openhab:milestone
# image: openhab/openhab:snapshot
container_name: openhab
restart: always
network_mode: host
volumes:
- /etc/localtime:/etc/localtime:ro
- /etc/timezone:/etc/timezone:ro
- ./.ssh:/openhab/.ssh
- ./openhab/.karaf:/openhab/.karaf
- ./openhab/conf:/openhab/conf
- ./openhab/userdata:/openhab/userdata
- ./openhab/addons:/openhab/addons
environment:
USER_ID: ${UID}
GROUP_ID: ${GID}
# Adjust accordingly
OPENHAB_HTTP_PORT: 8080
OPENHAB_HTTPS_PORT: 8443
JAVA_MIN_MEM: 4g
JAVA_MAX_MEM: 4g
mosquitto:
image: eclipse-mosquitto:latest
container_name: mosquitto
restart: always
volumes:
- ./mosquitto/mosquitto.conf:/mosquitto/config/mosquitto.conf
user: "${UID}:${GID}"
ports:
# These ports should not be changed unless absolutely necessary
- "1883:1883"
- "8883:8883"
zigbee2mqtt:
image: koenkk/zigbee2mqtt:latest
container_name: zigbee2mqtt
restart: always
# Make it run as the openhab user too
volumes:
- ./zigbee2mqtt:/app/data
ports:
- "8088:8080"
# Uncomment the devices section below and map the correct device
#devices:
#- /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0:/dev/ttyUSB0
depends_on:
- mosquitto
EOF
unset GID
[ -f docker-compose.yaml ] && echo Warning: docker-compose.yaml exists. compose.yml will take precedence.
mkdir -p openhab mosquitto zigbee2mqtt
[ -f mosquitto/mosquitto.conf ] || cat <<-EOF > mosquitto/mosquitto.conf
per_listener_settings true
port 1883
protocol mqtt
allow_anonymous true
allow_zero_length_clientid true
connection_messages true
EOF
docker compose up -d
Check to see if the containers are running
docker compose ps
Set the mqtt host in Zigbee2mqtt config:
sed -i 's#mqtt://localhost:#mqtt://mosquitto:#' zigbee2mqtt/configuration.yaml
docker compose restart zigbee2mqtt
Congratulations! You’ve now got openHAB up and running!
You should now be able to access openHAB’s web interface on http://your.server.ip:8080/
At this point Zigbee2MQTT isn’t fuly configured.
You need to set up the dongle/serial port mapping.
Read up on how to configure Zigbee2MQTT from https://www.zigbee2mqtt.io/guide/installation/02_docker.html,
especially about configuring the serial port to communicate with yout zigbee dongle.
The Zigbee2MQTT config file is located in zigbee2mqtt/configuration.yaml
