HP Printer binding Invalid URI host
In the Log Viewer I receive on going the following message:
2024-12-15 13:11:09.145 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Invalid URI host: null (authority: hereisaIPv6address)
	at org.eclipse.jetty.client.HttpClient.checkHost(HttpClient.java:541) ~[?:?]
	at org.eclipse.jetty.client.HttpClient.newHttpRequest(HttpClient.java:526) ~[?:?]
	at org.eclipse.jetty.client.HttpClient.newRequest(HttpClient.java:484) ~[?:?]
	at org.eclipse.jetty.client.HttpClient.newRequest(HttpClient.java:473) ~[?:?]
	at org.openhab.binding.hpprinter.internal.api.HPWebServerClient.fetchData(HPWebServerClient.java:105) ~[?:?]
	at org.openhab.binding.hpprinter.internal.api.HPWebServerClient.getProductUsageFeatures(HPWebServerClient.java:78) ~[?:?]
	at org.openhab.binding.hpprinter.internal.HPPrinterBinder.dynamicallyAddChannels(HPPrinterBinder.java:124) ~[?:?]
	at org.openhab.binding.hpprinter.internal.HPPrinterHandler.initializeScheduled(HPPrinterHandler.java:80) ~[?:?]
	at org.openhab.binding.hpprinter.internal.HPPrinterHandler.lambda$0(HPPrinterHandler.java:68) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
In the Thing configuration there you can see a switch between IPv4 and a IPv6 address. I thought to use the hostname. But the offered hostname of my CM1415fn is not valid in the configuration of the thing.
I can solve the problem with deactivating IPv6 on the Webinterface of the printer but then I run into a bigger problem with my wife - she can not print anymore. So another issue came up: Why cannot MacOS print with IPv4??? But that should not be the problem here.
Try replacing the clear text host name in your printer Thing configuration with its dotted ip v4 address. It would not be an actual solution but it could at least be a work around.
This is not the problem. The Thing does what it should. My post is only valid for the jumping IPv4 and IPv6 address. This is not like it should work. If I have a static Thing in a file. I do not have the switching IP.
