I’ve a rule which should analyze the RGB parts of the value of a colour item.
When I set the colour (e.g. with .sendCommand(HSBType::fromRGB(100, 100, 100)) the red, green and blue value will not be returned as 100 but instead I get the value of the brightness???.
Here is my rule:
rule "Farbcode setzen"
Item cLt_TerrasseLichtFarbe changed
var HSBType hsbValue
var int red
var int green
var int blue
var int bright
if (cLt_TerrasseLichtFarbe.state != UNDEF)
hsbValue = cLt_TerrasseLichtFarbe.state as HSBType
red = hsbValue.getRed.intValue
green = hsbValue.getGreen.intValue
blue = hsbValue.getBlue.intValue
bright = hsbValue.getBrightness.intValue
logInfo("Farbcode ", red.toString + ", " + green.toString + ", " + blue.toString + ", " + bright.toString)
if ((red == 100) && (green == 0) && (blue == 0)) // rot
Farbcode = 1
else if ((red == 100) && (green == 100) && (blue == 0)) // gelb
Farbcode = 2
else if ((red == 0) && (green == 100) && (blue == 0)) // grün
Farbcode = 3
else if ((red == 0) && (green == 100) && (blue == 100)) // cyan
Farbcode = 4
else if ((red == 0) && (green == 0) && (blue == 100)) // blau
Farbcode = 5
else if ((red == 100) && (green == 0) && (blue == 100)) // magenta
Farbcode = 6
else if (sLt_TerrasseLichtDisco.state == ON) // Disco-Modus
Farbcode = 7
else // frei definiert
Farbcode = 8
logInfo("Farbcode", Farbcode.toString)
nLt_TerrasseFarbe.postUpdate(Farbcode)
The logged values are:
2017-08-18 08:56:48.634 [INFO ] [pse.smarthome.model.script.Farbcode ] - 39, 39, 39, 39
If I use .red instead of .getRed it’s the same.
Any idea what’s wrong?
