When changing the Brightness
2021-03-20 19:45:10.608 [TRACE] [z.internal.handler.LightThingHandler] - Sending {"on":true,"bri":177} to light 5 via http://127.0.0.1:8090/api/6EE976EE01/lights/5/state
2021-03-20 19:45:10.631 [TRACE] [z.internal.handler.LightThingHandler] - Result code=200, body=[{"success":{"/lights/5/state/on":true}},{"success":{"/lights/5/state/bri":177}}]
2021-03-20 19:45:10.633 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"5","r":"lights","state":{"alert":null,"bri":177,"colormode":"ct","ct":392,"effect":null,"hue":0,"on":true,"reachable":true,"sat":254,"xy":[0.3209,0.1541]},"t":"event","uniqueid":"84:2e:14:ff:fe:2a:24:97-01"}
2021-03-20 19:45:10.634 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 166,100,0 to 166,100,70
2021-03-20 19:45:10.645 [TRACE] [z.internal.handler.LightThingHandler] - deconz:extendedcolorlight:c8d775a5:842e14fffe2a249701 received LightMessage{hascolor=null, ctmax=null, ctmin=null, type=null, state=LightState{reachable=true, on=true, bri=177, alert='null', colormode='ct', effect='null', hue=0, sat=254, ct=392, xy=[0.3209, 0.1541], transitiontime=null}, e='changed', r='lights', t='event', id='5', manufacturername='', modelid='', name='', swversion='', ep='', uniqueid='84:2e:14:ff:fe:2a:24:97-01'}
2021-03-20 19:45:10.650 [DEBUG] [z.internal.handler.LightThingHandler] - val = '254', scaledValue = '100'
2021-03-20 19:45:10.654 [DEBUG] [z.internal.handler.LightThingHandler] - val = '177', scaledValue = '70'
2021-03-20 19:45:10.660 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"1","r":"groups","state":{"all_on":false,"any_on":true},"t":"event"}
2021-03-20 19:45:10.664 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 166,100,70 to 0.0,100,70
2021-03-20 19:45:10.664 [DEBUG] [nternal.netutils.WebSocketConnection] - Unknown message type: groups
2021-03-20 19:45:10.805 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"5","r":"lights","state":{"alert":null,"bri":2,"colormode":"ct","ct":392,"effect":null,"hue":0,"on":true,"reachable":true,"sat":254,"xy":[0.3209,0.1541]},"t":"event","uniqueid":"84:2e:14:ff:fe:2a:24:97-01"}
2021-03-20 19:45:10.808 [TRACE] [z.internal.handler.LightThingHandler] - deconz:extendedcolorlight:c8d775a5:842e14fffe2a249701 received LightMessage{hascolor=null, ctmax=null, ctmin=null, type=null, state=LightState{reachable=true, on=true, bri=2, alert='null', colormode='ct', effect='null', hue=0, sat=254, ct=392, xy=[0.3209, 0.1541], transitiontime=null}, e='changed', r='lights', t='event', id='5', manufacturername='', modelid='', name='', swversion='', ep='', uniqueid='84:2e:14:ff:fe:2a:24:97-01'}
2021-03-20 19:45:10.810 [TRACE] [z.internal.handler.LightThingHandler] - Ignoring differing update after last command until 1616265910881
2021-03-20 19:45:11.748 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"5","r":"lights","state":{"alert":null,"bri":177,"colormode":"ct","ct":392,"effect":null,"hue":0,"on":true,"reachable":true,"sat":254,"xy":[0.3209,0.1541]},"t":"event","uniqueid":"84:2e:14:ff:fe:2a:24:97-01"}
2021-03-20 19:45:11.752 [TRACE] [z.internal.handler.LightThingHandler] - deconz:extendedcolorlight:c8d775a5:842e14fffe2a249701 received LightMessage{hascolor=null, ctmax=null, ctmin=null, type=null, state=LightState{reachable=true, on=true, bri=177, alert='null', colormode='ct', effect='null', hue=0, sat=254, ct=392, xy=[0.3209, 0.1541], transitiontime=null}, e='changed', r='lights', t='event', id='5', manufacturername='', modelid='', name='', swversion='', ep='', uniqueid='84:2e:14:ff:fe:2a:24:97-01'}
2021-03-20 19:45:11.756 [DEBUG] [z.internal.handler.LightThingHandler] - val = '254', scaledValue = '100'
2021-03-20 19:45:11.759 [DEBUG] [z.internal.handler.LightThingHandler] - val = '177', scaledValue = '70'
When changing the Color:
2021-03-20 19:46:27.228 [ome.event.ItemCommandEvent] - Item 'BettLinks_Color' received command 65,100,70
2021-03-20 19:46:27.235 [nt.ItemStatePredictedEvent] - BettLinks_Color predicted to become 65,100,70
2021-03-20 19:46:27.254 [TRACE] [z.internal.handler.LightThingHandler] - Sending {"bri":177,"hue":11832,"sat":254} to light 5 via http://127.0.0.1:8090/api/6EE976EE01/lights/5/state
2021-03-20 19:46:27.262 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"5","r":"lights","state":{"alert":null,"bri":177,"colormode":"hs","ct":392,"effect":null,"hue":11832,"on":true,"reachable":true,"sat":254,"xy":[0.3209,0.1541]},"t":"event","uniqueid":"84:2e:14:ff:fe:2a:24:97-01"}
2021-03-20 19:46:27.264 [TRACE] [z.internal.handler.LightThingHandler] - Result code=200, body=[{"success":{"/lights/5/state/bri":177}},{"success":{"/lights/5/state/hue":11832}},{"success":{"/lights/5/state/sat":254}}]
2021-03-20 19:46:27.264 [TRACE] [z.internal.handler.LightThingHandler] - deconz:extendedcolorlight:c8d775a5:842e14fffe2a249701 received LightMessage{hascolor=null, ctmax=null, ctmin=null, type=null, state=LightState{reachable=true, on=true, bri=177, alert='null', colormode='hs', effect='null', hue=11832, sat=254, ct=392, xy=[0.3209, 0.1541], transitiontime=null}, e='changed', r='lights', t='event', id='5', manufacturername='', modelid='', name='', swversion='', ep='', uniqueid='84:2e:14:ff:fe:2a:24:97-01'}
2021-03-20 19:46:27.268 [DEBUG] [z.internal.handler.LightThingHandler] - val = '254', scaledValue = '100'
2021-03-20 19:46:27.270 [DEBUG] [z.internal.handler.LightThingHandler] - val = '177', scaledValue = '70'
2021-03-20 19:46:27.275 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 0.0,100,70 to 65,100,70
2021-03-20 19:46:27.282 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 65,100,70 to 64.99610894941634,100,70
2021-03-20 19:46:27.721 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"5","r":"lights","state":{"alert":null,"bri":177,"colormode":"ct","ct":392,"effect":null,"hue":0,"on":true,"reachable":true,"sat":254,"xy":[0.3209,0.1541]},"t":"event","uniqueid":"84:2e:14:ff:fe:2a:24:97-01"}
2021-03-20 19:46:27.724 [TRACE] [z.internal.handler.LightThingHandler] - deconz:extendedcolorlight:c8d775a5:842e14fffe2a249701 received LightMessage{hascolor=null, ctmax=null, ctmin=null, type=null, state=LightState{reachable=true, on=true, bri=177, alert='null', colormode='ct', effect='null', hue=0, sat=254, ct=392, xy=[0.3209, 0.1541], transitiontime=null}, e='changed', r='lights', t='event', id='5', manufacturername='', modelid='', name='', swversion='', ep='', uniqueid='84:2e:14:ff:fe:2a:24:97-01'}
2021-03-20 19:46:27.727 [DEBUG] [z.internal.handler.LightThingHandler] - val = '254', scaledValue = '100'
2021-03-20 19:46:27.730 [DEBUG] [z.internal.handler.LightThingHandler] - val = '177', scaledValue = '70'
2021-03-20 19:46:27.744 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 64.99610894941634,100,70 to 0.0,100,70
2021-03-20 19:46:28.349 [ome.event.ItemCommandEvent] - Item 'BettLinks_Color' received command 280,100,70
2021-03-20 19:46:28.351 [nt.ItemStatePredictedEvent] - BettLinks_Color predicted to become 280,100,70
2021-03-20 19:46:28.382 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 0.0,100,70 to 280,100,70
2021-03-20 19:46:28.395 [TRACE] [z.internal.handler.LightThingHandler] - Sending {"bri":177,"hue":50971,"sat":254} to light 5 via http://127.0.0.1:8090/api/6EE976EE01/lights/5/state
2021-03-20 19:46:28.403 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"5","r":"lights","state":{"alert":null,"bri":177,"colormode":"hs","ct":392,"effect":null,"hue":50971,"on":true,"reachable":true,"sat":254,"xy":[0.3209,0.1541]},"t":"event","uniqueid":"84:2e:14:ff:fe:2a:24:97-01"}
2021-03-20 19:46:28.405 [TRACE] [z.internal.handler.LightThingHandler] - Result code=200, body=[{"success":{"/lights/5/state/bri":177}},{"success":{"/lights/5/state/hue":50971}},{"success":{"/lights/5/state/sat":254}}]
2021-03-20 19:46:28.406 [TRACE] [z.internal.handler.LightThingHandler] - deconz:extendedcolorlight:c8d775a5:842e14fffe2a249701 received LightMessage{hascolor=null, ctmax=null, ctmin=null, type=null, state=LightState{reachable=true, on=true, bri=177, alert='null', colormode='hs', effect='null', hue=50971, sat=254, ct=392, xy=[0.3209, 0.1541], transitiontime=null}, e='changed', r='lights', t='event', id='5', manufacturername='', modelid='', name='', swversion='', ep='', uniqueid='84:2e:14:ff:fe:2a:24:97-01'}
2021-03-20 19:46:28.414 [DEBUG] [z.internal.handler.LightThingHandler] - val = '254', scaledValue = '100'
2021-03-20 19:46:28.417 [DEBUG] [z.internal.handler.LightThingHandler] - val = '177', scaledValue = '70'
2021-03-20 19:46:28.426 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 280,100,70 to 279.9963378347448,100,70
2021-03-20 19:46:29.225 [ome.event.ItemCommandEvent] - Item 'BettLinks_Color' received command 280,100,70
2021-03-20 19:46:29.230 [nt.ItemStatePredictedEvent] - BettLinks_Color predicted to become 280,100,70
2021-03-20 19:46:29.253 [TRACE] [z.internal.handler.LightThingHandler] - Sending {"bri":177,"hue":50971,"sat":254} to light 5 via http://127.0.0.1:8090/api/6EE976EE01/lights/5/state
2021-03-20 19:46:29.261 [TRACE] [z.internal.handler.LightThingHandler] - Result code=200, body=[{"success":{"/lights/5/state/bri":177}},{"success":{"/lights/5/state/hue":50971}},{"success":{"/lights/5/state/sat":254}}]
2021-03-20 19:46:29.286 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 279.9963378347448,100,70 to 280,100,70
2021-03-20 19:46:32.725 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"5","r":"lights","state":{"alert":null,"bri":177,"colormode":"ct","ct":392,"effect":null,"hue":0,"on":true,"reachable":true,"sat":254,"xy":[0.3209,0.1541]},"t":"event","uniqueid":"84:2e:14:ff:fe:2a:24:97-01"}
2021-03-20 19:46:32.727 [TRACE] [z.internal.handler.LightThingHandler] - deconz:extendedcolorlight:c8d775a5:842e14fffe2a249701 received LightMessage{hascolor=null, ctmax=null, ctmin=null, type=null, state=LightState{reachable=true, on=true, bri=177, alert='null', colormode='ct', effect='null', hue=0, sat=254, ct=392, xy=[0.3209, 0.1541], transitiontime=null}, e='changed', r='lights', t='event', id='5', manufacturername='', modelid='', name='', swversion='', ep='', uniqueid='84:2e:14:ff:fe:2a:24:97-01'}
2021-03-20 19:46:32.730 [DEBUG] [z.internal.handler.LightThingHandler] - val = '254', scaledValue = '100'
2021-03-20 19:46:32.732 [DEBUG] [z.internal.handler.LightThingHandler] - val = '177', scaledValue = '70'
2021-03-20 19:46:32.738 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 280,100,70 to 0.0,100,70
To be honest I am a bit a n00b on this so I dont know how to change color mode to xy
And last, when I change via Phoscon GUI (working fine):
2021-03-20 19:54:18.470 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"5","r":"lights","state":{"alert":null,"bri":177,"colormode":"xy","ct":392,"effect":null,"hue":0,"on":true,"reachable":true,"sat":254,"xy":[0.1562,0.0361]},"t":"event","uniqueid":"84:2e:14:ff:fe:2a:24:97-01"}
2021-03-20 19:54:18.473 [TRACE] [z.internal.handler.LightThingHandler] - deconz:extendedcolorlight:c8d775a5:842e14fffe2a249701 received LightMessage{hascolor=null, ctmax=null, ctmin=null, type=null, state=LightState{reachable=true, on=true, bri=177, alert='null', colormode='xy', effect='null', hue=0, sat=254, ct=392, xy=[0.1562, 0.0361], transitiontime=null}, e='changed', r='lights', t='event', id='5', manufacturername='', modelid='', name='', swversion='', ep='', uniqueid='84:2e:14:ff:fe:2a:24:97-01'}
2021-03-20 19:54:18.479 [DEBUG] [z.internal.handler.LightThingHandler] - val = '177', scaledValue = '70'
2021-03-20 19:54:18.486 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 154,100,70 to 255,100,70
2021-03-20 19:54:19.471 [TRACE] [nternal.netutils.WebSocketConnection] - Raw data received by websocket: {"e":"changed","id":"5","r":"lights","state":{"alert":null,"bri":177,"colormode":"xy","ct":392,"effect":null,"hue":0,"on":true,"reachable":true,"sat":254,"xy":[0.1582,0.0187]},"t":"event","uniqueid":"84:2e:14:ff:fe:2a:24:97-01"}
2021-03-20 19:54:19.474 [TRACE] [z.internal.handler.LightThingHandler] - deconz:extendedcolorlight:c8d775a5:842e14fffe2a249701 received LightMessage{hascolor=null, ctmax=null, ctmin=null, type=null, state=LightState{reachable=true, on=true, bri=177, alert='null', colormode='xy', effect='null', hue=0, sat=254, ct=392, xy=[0.1582, 0.0187], transitiontime=null}, e='changed', r='lights', t='event', id='5', manufacturername='', modelid='', name='', swversion='', ep='', uniqueid='84:2e:14:ff:fe:2a:24:97-01'}
2021-03-20 19:54:19.477 [DEBUG] [z.internal.handler.LightThingHandler] - val = '177', scaledValue = '70'
2021-03-20 19:54:19.487 [vent.ItemStateChangedEvent] - BettLinks_Color changed from 255,100,70 to 259,100,70
