Hi
I’m trying to use the HTTP-Binding to modify the Config of a Shelly Plus Plug S
So far I have only managed to get the config, but every attempt to write it seems to disappear into nothingness.
Shelly background:
GET: http://192.168.66.64/rpc/PLUGS_UI.GetConfig
This returns a JSON-String
SET: http://192.168.66.64/rpc/PLUGS_UI.SetConfig?config={%22leds%22:%20{%22colors%22:%20{%22switch:0%22:%20{%22off%22:%20{%22brightness%22:%200.0}}}}}
This sets the Brightness to 0 when the Plug is “off” and both URLs can be called using a browser.
JSON-Path for GET is JSONPATH:$.leds.colors.switch:0.off.brightness
and works well.
This is my HTTP-Thing
UID: http:url:412d83813f
label: HTTP 192.168.66.64
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: http://192.168.66.64/rpc/
delay: 0
stateMethod: GET
refresh: 30
commandMethod: GET
contentType: application/json
timeout: 3000
bufferSize: 2048
channels:
- id: PLUGS_UI_GetConfig
channelTypeUID: http:string
label: PLUGS_UI.GetConfig
description: ""
configuration:
stateExtension: PLUGS_UI.GetConfig
commandExtension: PLUGS_UI.SetConfig?config=
- id: PLUGS_UI_GetConfig_OFF_Brrightness
channelTypeUID: http:number
label: PLUGS_UI.GetConfig Off Brightness
description: ""
configuration:
commandTransformation: JSONPATH:$.leds.colors.switch:0.off.brightness
stateTransformation: JSONPATH:$.leds.colors.switch:0.off.brightness
The first channel is linked to a String-Item and gives the full JSON.
The second channel is linked to a Number-Item and gives the value (as set using the WebGUI or the call above).
However when I try to set the value using the rule
events.postUpdate('HTTP_1921686664_PLUGS_UIGetConfig_Off_Brightness', 100);
All I get is a log entry
19:06:36.861 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'HTTP_1921686664_PLUGS_UIGetConfig_Off_Brightness' changed from 0.0 to 100
and a few seconds later (refresh time)
19:06:44.877 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'HTTP_1921686664_PLUGS_UIGetConfig_Off_Brightness' changed from 100 to 0.0
but as far as I can tell there is never a call to SetConfig made.
For debugging I tried pointing baseURL to my Webserver and view the logs, but only calls to GetConfig are logged. SetConfig is never accessed which leads me to think that there is something wrong in my Binding.
I really hope someone can point me in the right direction to use these Shelly-RPCs as changing the light on/off should have been just the beginning and not a dead end.
Thanks in advance for your patience and help.
Ingo
