I have a defined item
Switch LOCALWEATHER_observerreboot { http=">[ON:POST:http://192.168.1.5/msgreboot.htm]" }
and when the item turns ON (I do this by a rule at 1pm) it would like that the URL is called. (SImply accessing the URL does reboot a device and is needed as the device gets unstable after a while)
However the log shows: 2019-12-25 23:00:00.160 [ERROR] [org.openhab.io.net.http.HttpUtil ] - Fatal transport error: java.net.SocketException: Connection reset
Anybody knows what I am doing wring?
If you see a much simpler solution (e.g. without a item at all) to just “call” a URL at a given time please let me know.
http binding + regex reads another html page from that device to my weatherstation items .
I think the http binding just would throw a single error when it reads during the reboot and it should work once the reboot is done without any further hacks… hopefully
