Hello community,
I’ve got a little problem, and I’m kind of stuck. I can switch the switches (http binding) manually, but if they are switched via a rule, it just doesn’t work.
is there something wrong with my configuration?
lights.items:
Group:Switch:OR(ON,OFF) Lights "Alle Lampen"
Switch Wohnzimmer "Licht Wohnzimmer" (Lights) { http=">[ON:GET:http://192.168.15.53:5001/control?device=wohnzimmer&state=on] >[OFF:GET:http://192.168.15.53:5001/control?device=wohnzimmer$
Switch Kueche "Licht Küche" (Lights) { http=">[ON:GET:http://192.168.15.53:5001/control?device=kueche&state=on] >[OFF:GET:http://192.168.15.53:5001/control?device=kueche&state=off]" }
Switch Flur "Licht Flur" (Lights) { http=">[ON:GET:http://192.168.15.53:5001/control?device=flur&state=on] >[OFF:GET:http://192.168.15.53:5001/control?device=flur&state=off]" }
Switch Flur2 "Licht Wohnzimmer-Flur" (Lights) { http=">[ON:GET:http://192.168.15.53:5001/control?device=wohnzimmer-flur&state=on] >[OFF:GET:http://192.168.15.53:5001/control?device=wohnz$
Switch Flur3 "Licht Flur oben" (Lights) { http=">[ON:GET:http://192.168.15.53:5001/control?device=flur-oben&state=on] >[OFF:GET:http://192.168.15.53:5001/control?device=flur-oben&state=o$
Switch Kinderzimmer "Licht Kinderzimmer" (Lights) { http=">[ON:GET:http://192.168.15.53:5001/control?device=kinderzimmer&state=on] >[OFF:GET:http://192.168.15.53:5001/control?device=kind$
rule "light off evening"
Time cron "0 30 22 * * ?"
Wohnzimmer.sendCommand(OFF)
Kueche.sendCommand(OFF)
Flur.sendCommand(OFF)
Flur2.sendCommand(OFF)
Flur3.sendCommand(OFF)
//Lights.sendCommand(ON)
rule "light on before sunset"
Channel 'astro:sun:home-evt:set#event' triggered START
Wohnzimmer.sendCommand(ON)
Kueche.sendCommand(ON)
Flur.sendCommand(ON)
Flur2.sendCommand(ON)
Flur3.sendCommand(ON)
in the log I can see that the rule works, but the light is still on. I can turn it off via the app or basicui
log:
2018-08-27 22:29:37.428 [vent.ItemStateChangedEvent] - Current_DateTime changed from 2018-08-27T22:28:37.359+0200 to 2018-08-27T22:29:37.360+0200
2018-08-27 22:30:00.631 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command OFF
2018-08-27 22:30:00.651 [ome.event.ItemCommandEvent] - Item 'Kueche' received command OFF
2018-08-27 22:30:00.668 [ome.event.ItemCommandEvent] - Item 'Flur' received command OFF
2018-08-27 22:30:00.671 [ome.event.ItemCommandEvent] - Item 'Flur2' received command OFF
2018-08-27 22:30:00.674 [ome.event.ItemCommandEvent] - Item 'Flur3' received command OFF
2018-08-27 22:30:00.815 [vent.ItemStateChangedEvent] - Wohnzimmer changed from ON to OFF
2018-08-27 22:30:00.834 [GroupItemStateChangedEvent] - Lights changed from ON to OFF through Flur3
2018-08-27 22:30:00.842 [GroupItemStateChangedEvent] - Lights changed from ON to OFF through Flur2
2018-08-27 22:30:00.851 [vent.ItemStateChangedEvent] - Flur2 changed from ON to OFF
2018-08-27 22:30:37.409 [vent.ItemStateChangedEvent] - Current_DateTime changed from 2018-08-27T22:29:37.360+0200 to 2018-08-27T22:30:37.361+0200
