Ok, now I changed back to the same API as used on 2.5.
This is the trace output:
2021-05-25 23:05:47.933 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Sending to βhttp://192.168.110.203:8083/ZWaveAPI/Run/devices[4].instances[3].SensorMultilevel.data[1].val.valueβ: Method = {GET}, Headers = {Accept-Encoding: gzip, User-Agent: Jetty/9.4.20.v20190813}, Content = {null}
2021-05-25 23:05:47.970 [TRACE] [p.internal.http.HttpResponseListener] - Received from βhttp://192.168.110.203:8083/ZWaveAPI/Run/devices[4].instances[3].SensorMultilevel.data[1].val.valueβ: Code = {401}, Headers = {Server: Mongoose/6.4, Access-Control-Allow-Origin: *, Access-Control-Allow-Methods: GET, PUT, POST, DELETE, OPTIONS, Access-Control-Allow-Headers: Authorization, Accept-Ranges, Content-Encoding, Content-Length, Content-Range, Content-Type, ETag, X-API-VERSION, Date, Cache-Control, If-None-Match, Content-Language, Accept-Language, X-ZBW-SESSID, ZWAYSession, Access-Control-Expose-Headers: Authorization, Accept-Ranges, Content-Encoding, Content-Length, Content-Range, Content-Type, ETag, X-API-VERSION, Date, Cache-Control, If-None-Match, Content-Language, Accept-Language, X-ZBW-SESSID, ZWAYSession, Connection: keep-alive, Date: Tue, 25 May 2021 21:05:47 GMT, Content-Type: text/plain, Content-Length: 13}, Content = {Not logged in}
2021-05-25 23:05:47.972 [WARN ] [p.internal.http.HttpResponseListener] - Requesting βhttp://192.168.110.203:8083/ZWaveAPI/Run/devices[4].instances[3].SensorMultilevel.data[1].val.valueβ (method=βGETβ, content=βnullβ) failed: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
Config in 3:
UID: http:url:7e5ba49f4a
label: HTTP URL Thing
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: http://192.168.110.203:8083/ZWaveAPI/Run/
password: PW
refresh: 30
commandMethod: GET
contentType: text/plain
timeout: 3000
bufferSize: 2048
username: UN
channels:
- id: BH_Temp
channelTypeUID: http:number
label: BH_Temp
description: ββ
configuration:
stateExtension: devices%%5B4%%5D.instances%%5B3%%5D.SensorMultilevel.data%%5B1%%5D.val.value
format in 2.5:
{http="<[http://UN:PW@192.168.110.203:8083/ZWaveAPI/Run/devices%[4%].instances%[3%].SensorMultilevel.data%[1%].val.value:30000:REGEX((.*))]" }
