HTTP Binding: POST "content" not empty
I’m trying to deal with the REST API of “Proxmox” to start/stop virtual machines through openHAB. The state method works fine but the command method does not.
I already figured out what’s the reason for this issue:
The POST method always creates a string with the state value and inserts it into the request as “content”.
Excerpt from the log:
Sending to 'https://XYZ:8006/api2/..../status/shutdown': Method = {POST}, Headers = {Accept-Encoding: gzip, User-Agent: Jetty/9.4.43.v20210629, Content-Type: application/json, Authorization: PVEAPIToken=XXXX, Content = {shutdown}
The API endpoint can’t handle the content “{shutdown}”. So i need to send a POST request without any content. How can I realize this use case?
Greeting,
Vince
Can you post the configuration of your Thing and Channel, and also the Item linked to it?
Thing & Channel:
UID: http:url:proxmoxPVE
label: Proxmox Server
thingTypeUID: http:url
configuration:
  authMode: BASIC
  headers:
    - Authorization=PVEAPIToken=XXXXX
  ignoreSSLErrors: true
  baseURL: https://XYZ:8006/api2/json
  delay: 0
  stateMethod: GET
  refresh: 30
  commandMethod: POST
  contentType: application/json
  timeout: 3000
  bufferSize: 2048
channels:
  - id: lxc117
    channelTypeUID: http:switch
    label: LXC Server
    description: ""
    configuration:
      onValue: running
      commandTransformation: MAP:proxmox.map
      offValue: stopped
      stateExtension: /nodes/pve/lxc/117/status/current
      commandExtension: /nodes/pve/lxc/117/status/%2$s
      stateTransformation: JSONPATH:$.data.status
promox.map:
running=start
stopped=shutdown
The item is a “simple” switch.
Anyone?
Did you try to send commands using the get method ? I always use Firefox with RESTer to test what is the protocol and actual message format to use.
The API rejects start/stop commands by using the GET method. The POST method would work fine when the HTTP binding would send an empty “content”.
Unfortunately there is still no option in 4.2.0 to do a http (post) request by keeping the “content” empty.
Dear devoloper team, could you please extend the http binding with the option to keep the “content” empty for the “command” method?
