Http binding question - cache not working
Greetings all, just starting out with openHAB 2.0, using openhabian on a RPi3. I am trying to use the http binding cache to grab data from an Arduino webserver via a simple rest interface to display oil and propane tank levels. Openhab reads the data successfully if an http item defined using a direct URL, but when using the cache feature it fails.
So for instance, http.items set up for direct URL works:
Number oilLevel { http="<[http://opentank.home/xml:10000:REGEX(.*?<oil>(.*?)</oil>.*)]" }
but this does not:
Number oilLevel { http="<[opentank.Cache:10000:REGEX(.*?<oil>(.*?)</oil>.*)]" }
where my cache settings in http.cfg are as follows:
opentankCache.url=http://opentank.home/xml
opentankCache.updateInterval=60000
Regex transformation is installed and working.
openhab.log shows this error but based on the wiki I cannot see what’s wrong with my http.cfg
2017-03-18 17:54:23.607 [ERROR] [ab.binding.http.internal.HttpBinding] - given config key 'format' does not follow the expected pattern '<id>.<url|updateInterval>'
What’s the best way to troubleshoot this?
Maybe you should remove the dot?
opentank.Cache used in Item, but opentankCache specified as cache name.
Good catch, thank you very much.
I have the same error:
and my configuration is:
MKTronic.url=http://192.168.2.20/status.xml{Authorization=Basic YWRtaW46YWRtaW4=}
MKTronic.updateInterval=2000
and usage:
String Relay1Status { http="<[MKTronic:2000:REGEX(.*?<relay1>(.*?)</relay1>.*)]" }
This comes from having the format configuration parameter in your http.cfg file.
