Http Binding - strange behavior
Hello guys,
I am struggling with my http binding.
As far as i see - and copy/paste with my other things/items - I can not evaluate where my issue is:
thing
http:url:outdoorphoneCall "Gegensprechanlage Anruf" [ baseURL="http://192.168.0.58/api/call/status/", refresh=100]
    Channels:
        Type string : callstatus "Callstatus" [ stateTransformation="JSONPATH:$.data.Status" ]
behind the baseURL the output is as follows:
{ “retcode”: 0, “action”: “status”, “message”: “OK”, “data”: { “Status”: “READY” } }
item
String OA_Gateway_CallStatus "Telefonstatus [%s]" (Phone) { channel="http:url:outdoorphoneCall:callstatus"}
status of OA_Gateway_CallStatus is “NULL”.
May someone can give me a hint on this topic.
many thanks in advance
Maybe only copy&paste error, but there is a missing closing curly bracket (Item definition)
JSONPATH seems ok to me (beside wrong quotes, which may be also a copy&paste error).
	"retcode": 0,
	"action": "status",
	"message": "OK",
	"data": {
		"Status": "READY"
thanks for your fast reply.
Unfortunately that wasn’t the issue …
(just a copy/paste error)
What do you mean with “wrong quotes”?
I get this from my device and just want to read the status out of it…
	"retcode": 0,
	"action": "status",
	"message": "OK",
	"data": {
		"Status": "READY"
thanks for your help
Please take a closer look at your first quote of JSON (first post):
formatted as code.
You’ll see the quotes are different from those in your second quote (last post):
	"retcode": 0,
	"action": "status",
	"message": "OK",
	"data": {
		"Status": "READY"
It’s not as visible as it should be… But unfortunately this isn’t the issue either…
Just to be sure… You did install JSONPATH Transformation Service?
thanks for your answer.
It seems, that I have a general issue with my http binding.
Need some further debug sessions > If i find a solution, i will give an update.
thanks in advance
Hello again,
okay, I am out of ideas:
I have a “http thing” for fetching the cheapest gasprices > works
My device at home (outdoor phone) is online, gives the data above and haven’t a authentification. > doesn’t work
no special settigns or anything else > wrote a short python script and everything is fine > only via OH3 it isn’t possible.
very pleased for any inupts
Guess what, we are out of ideas as well!
Especially when reading your last post.
What is the information about the (working) http thing for gas prices for?
You tell that your “outdoor phone” is online and is giving data. So far all good, but “..haven’t a authentification. > doesn’t work”???
Then you are talking about a working pyton script, which isn’t wotürking via openHAB.
You started off with a problem using the HTTP binding and now you are trying a python script.
I m lost!
Many thanks for your professional input…
a) I just wanted to say, that the http binding is working
b) with the python script i just wanted to mention, that the device is “reachable” from my machine and i get an answer.
So I am open for further questions so that i can evaluate the issue.
Please share the used (working) python script.
Additionally please share any log-entries from the (not working) http thing/item.
python script:
import urllib.request, json
from jsonpath_ng import jsonpath, parse
with urllib.request.urlopen("http://192.168.0.58/api/call/status") as url:
    data = json.loads(url.read().decode())
    print(data)
    Status = data['data']
    print(Status)
output = parse('data.Status')
for match in output.find(data):
    print(f'{match.value}')
oddly enough, there aren’t any specific log-entries due to any errors. This was my first way before i posted something. Unfortunately I have to search, why I don’t have any ERROR or WARN entries.
These are the main entries i got currently:
2022-08-12 19:30:11.138 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘http:url:Akuvox’ changed from ONLINE to UNINITIALIZED
2022-08-12 19:30:11.170 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Stopped refresh task for URL ‘http://192.168.0.58/api/call/status
2022-08-12 19:30:11.172 [TRACE] [.HttpDynamicStateDescriptionProvider] - removing state description for thing http:url:Akuvox
2022-08-12 19:30:11.182 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘http:url:Akuvox’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-08-12 19:30:11.194 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘http:url:outdoorphone’ changed from UNINITIALIZED to INITIALIZING
2022-08-12 19:30:11.211 [DEBUG] [nding.http.internal.HttpThingHandler] - No authentication configured for thing ‘http:url:outdoorphone’
2022-08-12 19:30:11.211 [INFO ] [nding.http.internal.HttpThingHandler] - Using the secure client for thing ‘http:url:outdoorphone’.
2022-08-12 19:30:11.214 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Started refresh task for URL ‘http://192.168.0.58/api/system/info/’ with interval 100s
2022-08-12 19:30:11.214 [TRACE] [.HttpDynamicStateDescriptionProvider] - adding state description for channel http:url:outdoorphone:Status
2022-08-12 19:30:11.216 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘http:url:outdoorphone’ changed from INITIALIZING to ONLINE
2022-08-12 19:30:11.219 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘http:url:outdoorphoneCall’ changed from UNINITIALIZED to INITIALIZING
2022-08-12 19:30:11.225 [DEBUG] [nding.http.internal.HttpThingHandler] - No authentication configured for thing ‘http:url:outdoorphoneCall’
2022-08-12 19:30:11.226 [INFO ] [nding.http.internal.HttpThingHandler] - Using the secure client for thing ‘http:url:outdoorphoneCall’.
2022-08-12 19:30:11.227 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Started refresh task for URL ‘http://192.168.0.58/api/call/status/’ with interval 100s
2022-08-12 19:30:11.228 [TRACE] [.HttpDynamicStateDescriptionProvider] - adding state description for channel http:url:outdoorphoneCall:callstatus
2022-08-12 19:30:11.229 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘http:url:outdoorphoneCall’ changed from INITIALIZING to ONLINE
2022-08-12 19:30:11.232 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘http:url:outdoorphoneInput’ changed from UNINITIALIZED to INITIALIZING
2022-08-12 19:30:11.237 [DEBUG] [nding.http.internal.HttpThingHandler] - No authentication configured for thing ‘http:url:outdoorphoneInput’
2022-08-12 19:30:11.239 [INFO ] [nding.http.internal.HttpThingHandler] - Using the secure client for thing ‘http:url:outdoorphoneInput’.
2022-08-12 19:30:11.249 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Started refresh task for URL ‘http://192.168.0.58/api/input/status/’ with interval 20s
2022-08-12 19:30:11.250 [TRACE] [.HttpDynamicStateDescriptionProvider] - adding state description for channel http:url:outdoorphoneInput:DoorInputA
2022-08-12 19:30:11.252 [TRACE] [.HttpDynamicStateDescriptionProvider] - adding state description for channel http:url:outdoorphoneInput:DoorInputB
thx
Could you post the thing configuration as MainUI shows it on the code tab?
UID: http:url:outdoorphoneCall
label: Gegensprechanlage Anruf
thingTypeUID: http:url
configuration:
  authMode: BASIC
  ignoreSSLErrors: false
  baseURL: http://192.168.0.58/api/call/status/
  refresh: 100
  commandMethod: GET
  timeout: 3000
  bufferSize: 2048
channels:
  - id: callstatus
    channelTypeUID: http:string
    label: Callstatus
    description: null
    configuration:
      mode: READWRITE
      stateTransformation: JSONPATH:$.data.Status
My used http thing has this code:
UID: http:url:TasmotaVersion
label: Tasmota Version
configuration:
  authMode: BASIC
  baseURL: https://api.github.com/repos/arendst/Tasmota/tags
  delay: 0
  stateMethod: GET
  refresh: 43000
  commandMethod: GET
  contentType: application/json
  timeout: 5000
  bufferSize: 2048
channels:
  - id: Version
    label: Version
    description: ""
    configuration:
      stateTransformation: JSONPATH:$[0].name
Note the used setting for statedescription. Can’t say if that does the trick, however…
One slash …
vs.
I did several tries in order to receive the return message (“NULL”). None did show your result ( included adding a slash at the end of the URL). I am out of ideas.
Puting my binding into TRACE logging is showing following messages:
2022-08-13 08:14:21.481 [TRACE] [.HttpDynamicStateDescriptionProvider] - removing state description for thing http:url:TasmotaVersion
2022-08-13 08:14:21.488 [INFO ] [nding.http.internal.HttpThingHandler] - Using the secure client for thing 'http:url:TasmotaVersion'.
2022-08-13 08:14:21.490 [DEBUG] [nding.http.internal.HttpThingHandler] - No authentication configured for thing 'http:url:TasmotaVersion'
2022-08-13 08:14:21.494 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Started refresh task for URL 'https://api.github.com/repos/arendst/Tasmota/tags' with interval 600s
2022-08-13 08:14:21.496 [TRACE] [.HttpDynamicStateDescriptionProvider] - adding state description for channel http:url:TasmotaVersion:Version
2022-08-13 08:14:22.495 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Requesting refresh (retry=false) from 'https://api.github.com/repos/arendst/Tasmota/tags' with timeout 5000ms
2022-08-13 08:14:22.498 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Sending to 'https://api.github.com/repos/arendst/Tasmota/tags': Method = {GET}, Headers = {Accept-Encoding: gzip, User-Agent: Jetty/9.4.46.v20220331}, Content = {null}
2022-08-13 08:14:22.534 [TRACE] [p.internal.http.HttpResponseListener] - Received from 'https://api.github.com/repos/arendst/Tasmota/tags': Code = ......( ommitted the full print of the return)
Your log sems to be missing the last three reports.
Are you using three different things (outdoorphone, outdoorphoneCall and outdoorphoneInput)?
Hello guys,
tell you what:
its working (right now)
Made a complete restart of OH3 and not only a “http Binding” restart, and now i get log entries and answer from my device.
sorry and big thanks to you…
