HTTP Binding with dynamic Authorization
  • Platform information:
    • Hardware: Pi
    • OS: Openhabian
  • Issue of the topic: HTTP Binding
I’m trying to configure the HTTP binding to boost my the hot water. I have the API working correctly with POSTMAN. However, I’m having some difficulty setting it up:
My config:
Switch item_boost_water “Boost Water” {http=“>[ON:POST:https://eu-https.topband-cloud.com/ember-back/zones/boost{Authorization=XXXXXXXX&Accept=application/json}:{ “hours”: “1”, “zoneid”: “1234” }] >[OFF:POST:https://eu-https.topband-cloud.com/ember-back/zones/boost{Authorization=XXXXXXX&Accept=application/json}:{ “hours”: “0”, “zoneid”: “1234” }]”}
My two issues are:
It doesn’t appear to like the JSON post data, do I need to escape or wrap it in some way. I don’t need to parse it, so I’m presuming I don’t need the JSON transformation.
The Authorization expires after an hour. There is a separate request to refresh it. What is the best practice for doing this, and how do I pass it to the command - I couldn’t see how to do that from the documentation.
Apologies if this has been answered elsewhere and I missed it.
You will need to switch to using Rules and the sendHTTP actions. You can see an example that does something similar in OAuth2 using just OH Rules and myopenhab.org.
Thank you.
I suspect it’s nearly as much work as creating a binding (which is a guess because I haven’t done either).
