If logs where generated please post these here using code fences:
I am very much beginner and not tech guy.
Earlier everything was working fine. However, when I tried to connect to OpenHAB cloud, the system was showing OFFLINE. When worked around in community, came to know the problem might be with java. Hence, installed java8. After then, I could not access 192.168.1.103:8080.
Java is listening to Port 8080.
Please help. Many searches in forum didn’t solve the problem.
When I try to check status of openhab2 service, I get following result. Why java in listening to 8080? Is that correct? And why java is main PID in openhab2 service?
pi@raspberrypi:~ $ sudo systemctl status openhab2.service
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service
enabled)
Active: active (running) since Sat 2018-04-07 07:59:48 I
T; 1min 40s ago
Docs: http://docs.openhab.org https://community.openhab.org
Main PID: 563 (java)
CGroup: /system.slice/openhab2.service
└─563 /usr/bin/java -Dopenhab.home=/usr/share/…
Apr 07 07:59:48 raspberrypi systemd[1]: Started openHAB 2…
Hint: Some lines were ellipsized, use -l to show in full.
