Hi guys.
I’m in the process of switching over to OH2 from OH1. I have worked out a lot of the differences and managed to get by with some struggling. But I’m stuck on being able to change/update the state of an item over a HTTP PUT command. What used to work:
http://192.168.0.16:8080/CMD?Office_Light=ON
no longer works. After searching, I gather this was a function of the old Classic UI, and it seems something like:
http://192.168.0.16:8080/rest/items/Office_Light/state=ON
should work, but I get a 404 error in the browser and the item state is not changed.
Also when I checkout the openHAB REST API section there is a red error warning at the bottom which upon clicking reads:
{"schemaValidationMessages":[{"level":"error","message":"Can't read from file http://192.168.0.16:8080/rest/swagger.json"}]}
Could this be the reason the http command doesn’t work? What could cause this error and where do I start to rectify it? Any help would be greatly appreciated, thank you in advance.
Liam.
