I want to send some commands to my Shellys. But i have absolutely no idea how the HTTP requests work. Even Actions | openHAB did not explained it to me as i hoped.
i got three parameters:
turn = on (turns the light on)
brightness = 100 (sets the brightness to 100%)
transition = 0 (transition time from 0% to 100% in 0ms)
Now i need to add them into an Http Reques with a rule. And now i am encountering all problems. I dont know how. Can someone explain it a bit to me?
rule "Testrule"
something triggers
sendHttpPutRequest("http://192.168.178.98/light/0?", "body", "brightness=10")
I know that my current rule is wrong, but i dont know how to modify the request until its working.
Thank you very much. For my understanding a GET Request is there to get some informations and store them e.g. in a variable.
A PUT request is to update some informations. Why is it better to use get request here?
For what i am trying to do the shelly binding isnt working. It is sort of limited.
read the Wikipedia entry on HTTP for a basic understanding:
As I said, I don’t have any Shellys and don’t know about their Web-API. But if there’s a GET-based API, then just use it. If there’s a POST-based API, you’ll have to use that. You can’t change the way an API works on the Client-side. ever.
The Shellys obviously use an GET-based API, so there’s that.-
You’re right, as GET should be used for retrieving information, but obviously Shelly did it otherwise.
