- Platform information:
- Hardware: RPI/4GB
openhabian@openhabian:~ $ uname -a
Linux openhabian 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
- OS: openhabian 1.8b
- Java Runtime Environment: whatever is on openhabian 1.8b
- Issue of the topic:
https://openhabian:8080
doesn’t work, but http works OK
The error:
Secure Connection Failed
An error occurred during a connection to openhabian:8080
. SSL received a record that exceeded the maximum permissible length.
Error code: SSL_ERROR_RX_RECORD_TOO_LONG
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
It’s a fresh install + migration of settings from previous machine using backup & restore method. I also added openhabian hostname to the router (Turris Omnia) configuration.
Can I provide more info to help with diagnosing where is the problem? I’m using a router provided by the internet provider and Turris Omnia ar the real router serving LAN. Could that make a problem with obtaining the cert?
