Huawei LTE router statistic
How to do same with HTTP binding ? Most interesting part is authentication…
 #! / bin / sh
clear
RESPONSE = `curl -s -X GET http: // 192.168.8.1 / api / webserver / SesTokInfo`
COOKIE = `echo" $ RESPONSE "| grep SessionID = | cut -b 10-147`
TOKEN = `echo" $ RESPONSE "| grep TokInfo | cut -b 10-41`
curl -s http://192.168.8.1/api/device/signal -H "Cookie: $ COOKIE" -H "__RequestVerificationToken: $ TOKEN" -o Signal.txt
cat Signal.txt | grep rsrp
cat Signal.txt | grep rsrq
cat Signal.txt | grep rssi
cat Signal.txt | grep sinr
That looks like a pretty standard REST API. Most I have seen just use a token but I could envision adding a cookie too.
But HTTP binding wont handle it… how to solve this in easy way?
You might find some hints here.
