Hi all,
Random question that I’m sure has an easy answer but I’ve been staring at it for so long I’m going crazy.
Setting up my Hue bridge and lights, the hue binding is installed, and is correct as a thing…auto detect has found all the bulbs / motion sensors / switches so game on I thought:
I’ve picked the first bulb in my inbox after detection and added to my things via PaperUI:
All good so far, I add it to my lights.items file as both dimmer and switch so I can control on/off and brightness if I wish:
And then to test, I add it to my default.sitemap
So I can play around with it in the Basic UI and give it a test before moving on…
And here’s the problem, it won’t control the light, the switch and dimmer do absolutely nothing.
In the log file I get the following error:
and every now and then I get a Warning:
It seems to imply that the item couldn’t be found in the item registry, but I’m pretty sure it is…or is it???
Any help gratefully received before I rename it Broken_Hue_Bulb…
RaspPi3 / OpenHabian 2.4.0
